社区
Fusion 产品技术应用讨论区
欢迎访问欧特克Fusion (原名 Fusion 360)论坛!分享知识,发帖提问,浏览Fusion 热帖。
取消
显示结果
显示  仅  | 搜索替代
您的意思是:
Please help with how to copy and turn entities of sheet metal material into components.
4 条回复4
已解决
回复
1 条消息(共 5 条)
ciliu
321 次查看, 4 条回复
請協助了解如何將鈑金材料實體複製並轉換為組件。
[Translated with Google]
Please help on how to copy and convert sheet metal material solids into components.
4 条回复4
2 条消息(共 5 条)
davebYYPCU
回复: ciliu
Make a copy body with Boundary Fill, and it can be converted to Component.
or
Make a Sheetmetal Component and then make the part in it.  (Rule #1)
Might help...
3 条消息(共 5 条)
CGBenner
回复: ciliu
@ciliu
歡迎來到社區。我已將您的帖子移至此論壇以獲得更好的可見性。
如果您喜歡用中文發帖,您也可以在我們的中文 Fusion 論壇中發布您的問題。
祝你好運!
Welcome to the Community. I've moved your post to this forum for better visibility.
If you are more comfortable posting in Chinese, you may also post your questions in our Chinese language Fusion forum.
Good luck!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
4 条消息(共 5 条)
Take a look at the Blog Article and Video.
John Hackney, Retired
5 条消息(共 5 条)
Lev2978
回复: ciliu
你好,由于钣金部件与钣金规则关联,因此不支持直接将钣金实体转换为零部件。合理的做法是新建零部件并激活然后在项目里建模钣金,这样可将钣金件成为零部件。
如果您的问题得到了解决,请点击 " 接受解答 " 按钮。这样可以帮助其他人更快的找到解决方案!
李向明
找不到想要的内容?向社区提问或分享您的知识。
到论坛发帖
