YES/NO Formula to toggle component visibility?
doncawley
doncawley
I would like to create a true/false formula that toggles on / off the visibility of a component.  Is this possible and if so, how?
Thank you!
BrianEkins
Where are you expecting to define this formula?  What you're asking is simple if you write a script or add-in.  In that case the logic and the work to change the visibility is in the script or add-in.  With a script, you would need to run it and with an add-in you can have a command to make it simpler to run or trigger off of an event to do it.
If you don't want to write any code but do something like define a parameter that would control the visibility, that's not supported by Fusion.
Brian Ekins
