Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Would like to develop an add-in .
2 REPLIES 2
StephenCim-001
181 Views, 2 Replies
Hi All
Been thinking about developing an add-in but would like some basic advice on what's possible .
I'm thinking it's should be basic but no have no idea about F360 API.
I would like a couple of drop down menus , the first one would contain a List of Names, i.e USA, Australia , Japan .etc... . On selecting a Country and second drop down list would be populated with a list of standard Rings sizes for the Selected Country, I.e USA would have 1, 1 1/4, 1 1/2, 1 3/4, 2......
Australia Would have A, A 1/2, B, B 1/2, ........  On selecting a Ring Size, a parameter in the design, called RingSize would be set to the Diameter (mm) of the selected size, so would need some sort of look up table.
Would something like this be do able?
Here is a quick mockup .
 Any advice would be greatly appreciated 🙂
Cheers, Stephen
2 REPLIES 2
You can check this Haas app with source code inside and you can see lookup fields changes on user selection.
https://apps.autodesk.com/FUSION/en/Detail/Index?id=8728464278159145728&appLang=en&os=Win64
Parameters can be changed with
des = adsk.fusion.Design.cast(_app.activeProduct)
userParams = des.userParameters
userParams.itemByName('RingSize').expression =inputs.itemById('ringsize').expression
Thanks, Thats a starting point.
