Announcements
Working with multiple bodied component and with joints
fusionaip
fusionaip
I have a problem when i make a component that contains several bodies, or import one- when i use the joint command it only comes as one item if I combine all the bodies into one component. Is there a solution to this problem that does not involve the "combine" command?
marshaltu
I would like to recommend you create component for each body if you want to add joint among those bodies. "Joint" can only work with "component".
Marshal
Marshal Tu
Fusion Developer
