Announcements
Why is message box required to observe the updates in dialog's parameters?
@MattWynn @BrianEkins
If the message box is not provided then the below/next command is executed before opening the dialog.
m_Application->executeTextCommand("Commands.SetString infoStudyComments Comments");
Hence we don't see any update. Please refer to the GIF for a better understanding.
GIF: If a message box is present
void updateParameters()
    m_Application->executeTextCommand("Commands.Start MSFNestPrepareNestCmd");
    m_UserInterface->messageBox("Updating parameters...");
    m_UserInterface->messageBox("Updated");
GIF: If a message box is not present
BrianEkins
I don't know if you're going to find much help with attempting to drive dialogs using text commands. Any use of text commands is unsupported and as a result, it's not something I've spent any time investigating because of the unreliability. Since text commands aren't supported they could change at any time and in the workflow you're using, if the command dialog changes you'll also be broken.
However, I know when there isn't API support you don't have any other options.  I know I have projects that are sitting waiting for future functionality that I hope will come someday.
Brian Ekins
MattWynn
@Anonymous This is beyond my limited experience with the API.  You are on your own with using this functionality.  Using text commands from API is unsupported - meaning it is subject to change without notice.  Especially beware of the hidden text commands which will change or get removed without notice.
Matt Wynn
Senior Manager, Software Development, Fusion Fabrication
