Announcements
When you get a public link, you share it
kandennti
kandennti
Hi there.
Using the dataFile.publicLink property, a data file that has not been shared will switch to a shared state.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        datas = app.data.activeFolder.dataFiles.asArray()
        data: adsk.core.DataFile = datas[0]
        app.log(f'ver {app.version}')
        app.log(f'{data.name}.{data.fileExtension}')
        app.log(data.publicLink)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
This feels like an undesirable state.
BrianEkins
Why is this an undesirable state? It seems like that is essentially the same behavior as you see in the UI. The thing the API is missing is the switch to turn off sharing.
Brian Ekins
kandennti
Thanks for the reply @BrianEkins .
I was expecting the value of the dataFile.publicLink property to be an empty string if sharing is turned off.
I don't mind that the dataFile.publicLink property is not an empty string, but I don't want sharing to be turned on by itself.
For this matter, I have confirmed that sharing is also turned on by itself when operated with a web browser. (All in Japanese).
https://forums.autodesk.com/t5/fusion-360-ri-ben-yu/gong-yourinkugaonnisareteshimau/td-p/11248968
I have a feeling that this is not just an API problem.
