Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
When will you be able to provide a full stack API both 2D and 3D?
2 REPLIES 2
johan.svensson6BXFK
121 Views, 2 Replies
I have already asked this question on a reply, but I didn't get a reply.
Therefore again...
I have now ideas for at least 2 new plugins which require a 2D drawing API.
Isn't it time now to release a full featured API in order for the community to be able to thrive and Fusion functionality to grow?
I’ve discovered missing features in the Fusion 360 program that I would like to make new plugins for.
So when will you be able to provide the 2D API for developers?
2 REPLIES 2
Hi @johan.svensson6BXFK .
I do not know the answer to this question.
However, I have used TextCommands from the API in the past to draw simple circles and lines in drawings.
I have also confirmed that the lines are saved in the document.
There is a command in TextCommands that executes an AutoCAD command.(I have no experience with AutoCAD.)
FusionDoc.ExecuteAcadCommand                     - Execute AutoCAD Command
https://github.com/kantoku-code/Fusion360_Small_Tools_for_Developers/blob/75fbdec6aa9e6e27c88778699c...
  • Autodesk deprecates the use of TextCommands.
  • As for TextCommands, you will have to do a lot of experimenting on your own, as no one knows the answer.
  • The list of commands linked above is an older version. We recommend that you get the most up-to-date list.
    For more information on how to obtain and use the list of commands, please see the link .
  • If you find out something, it would be very helpful if you could leave a note on the forum, so that others can benefit from the information.
Thanks, I will look into it and see if this could be away forward.
But what I would really like to see is the full map, because this could really help a most innovative community and fast forward the third party development of new and possibly great features that is missing.
BR
Johan
