Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
What UI Framework is the Fusion 360 User Interface built on?
1 REPLY 1
nicciglen
1408 Views, 1 Reply
Just wondering - to get an idea of what the possibilities may be for styling colours etc. for the Fusion 360 UI for visual accessibility reasons ...
... What UI Framework is the Fusion 360 User Interface built on? - I'm guessing it's some kind of C++ UI framework?
(I'm hoping it's something standard)
Glen
Glen Johnson
Email: nicciglen[at]hotmail.com
LinkedIn: linkedin.com/in/glenjohnsonsofteng/
1 REPLY 1
ekinsb
in reply to: nicciglen
The Fusion 360 UI is created using Qt.  However, we don't ever plan on directly exposing the Qt capabilities through either the Qt library or the API.  For the most part, the API will just tend to expose what's already available in the UI.  Although there are cases where we'll provided some additional capabilities.  For example, we've begun work on exposing browser customization and will allow choosing some colors for the items that make up a browser node.  But even in this case rather than being able to specify any RGB value it will be from a list of pre-defined colors to help keep consistency throughout the product.
Brian Ekins
Mod the Machine blog
