Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
What is the unit of adsk.core.Point3D.create ?
1 REPLY 1
fabrice.salvaire
335 Views, 1 Reply
My design is set to mm unit.
This code generates points at (0,0), (10,-20), etc.
It looks like the unit is cm rather than mm.
for i in range(10):
    points.add(adsk.core.Point3D.create(i,i*2,0))
1 REPLY 1
Hi @fabrice.salvaire
The internal unit of fusion is "cm". when you use scripts or API it always uses the internal unit,
you can find more details about the how units working inside fusion here
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-A81B295F-984A-4039-B1CF-B449BEE893D7
Boopathi Sivakumar
Senior Technology Consultant
