Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Well... this is embarrassing. Looks like we lost your page.
5 REPLIES 5
f.brinkman
725 Views, 5 Replies
Every time I go back on a link of the API Reference in IE I see this error message :
(https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-7B5A90C8-E94C-48DA-B16B-430729B734DC)
In FireFox the links don't work at all, FireFox waits for ever.
It would be nice if you made real links so that you could open them in a new tab. That would probably also solve this problem
5 REPLIES 5
fusion360Z3TN7
in reply to: f.brinkman
Seems broken, it's really annoying because the API docs are not great to begin with with very few examples and when U try to search, you keep coming to this dead end .  I don't think it matters which browser you use.
In the meantime, I found the offline CHM version here
fabrinkman
in reply to: fusion360Z3TN7
Thank you for your link, this is very helpful.
pludikar
in reply to: fabrinkman
@Phil.E
It looks like this is an AD server issue.  I get exactly the same.  Using direct saved links or links from Google, result in 404 error.  Direct Links from the F360 learning space (here) do work, but using the back button results in 404 too
I'm not an expert, but I know enough to be very, very dangerous.
Life long R&D Engineer (retired after 30+ years in Military Communications, Aerospace Robotics and Transport Automation).
Phil.E
in reply to: pludikar
Thanks for the notice. Strangely enough, I was just writing the bug report for this as I am testing some of these links right this moment. That is some synchronicity if I've ever seen it.
We'll get this looked at immediately. Sorry for the trouble.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Tags (1)
goyals
in reply to: Phil.E
The links are fixed now. We are sorry for taking long time to fix it.
Shyam Goyal
Sr. Software Dev. Manager
