I've asked this question on a Python Discord server, but the people that helped me there were not able to help me with this one. I'm hoping someone here can help me with the extended class of which Fusion Python says cannot access a member of the parent class.
The error I get is:
File "/Users/user/Library/Application Support/Autodesk/Autodesk Fusion 360/API/Scripts/NewScript1/modules/VKR/order.py", line 86, in __init__
app.log(str(self.__filesWithInfo))
AttributeError: 'PriorityFiles' object has no attribute '_PriorityFiles__filesWithInfo'
Since there are no line-numbers in the snippet, I've added a comment of #error in the line that produces the error. As far as I can see, I've correctly extended the FilesWithInfo class with the PriorityFiles class. Yet, the child-class does not seem to have access to the parent's class member self.__filesWithInfo. What am I doing wrong?
Module to handle checking if there are files to be processed.
import adsk.core, adsk.fusion, adsk.cam, traceback
import os
from ..VKR.options import OPTIONS
app = adsk.core.Application.get()
class OrderFile:
''' A file that has been found in the orders directory that needs to be prioritized '''
def __init__( self, name: str ):
self.name: str = name
self._mod_time: int = None
self._priority_level: int = 0
def mod_time( self ) -> int:
''' Modification time '''
return self._mod_time
_time.setter
def mod_time( self, time: int ):
self._mod_time = time
def priority_level( self ) -> int:
''' The priority level of the file '''
return self._priority_level
_level.setter
def priority_level( self, priority: int ):
self._priority_level = priority
class FilesWithInfo:
''' A holder for filenames with information stored about the files '''
def __init__( self, files: list[ OrderFile ] = [] ):
self.__filesWithInfo = files
def add( self, file: OrderFile ):
''' Add a file with information to the storage '''
self.__filesWithInfo.append( file )
def length( self ):
''' Return the amount of stored files '''
return len( self.__filesWithInfo )
def priorities( self ) -> list[ OrderFile ] or None:
''' Return only the files that have priority or return None '''
ret = list( filter( lambda x: int( x.priority_level ) > 0, self.__filesWithInfo ))
ret2 = PriorityFiles( ret )
return ret2 if ret2.length > 0 else None
def oldest( self, files: list[ OrderFile ] ) -> OrderFile:
''' Return the oldest file '''
ret = None
for x in files:
if ret and x.mod_time < ret.mod_time:
ret = x
return ret
class PriorityFiles( FilesWithInfo ):
''' FilesWithInfo, but then for priority files only '''
super().__init__( files )
app.log(str(self.__filesWithInfo)) #error
def highest( self ) -> OrderFile:
''' Return the filename that has the highest priority '''
highest = None
for f in self.__filesWithInfo:
if highest:
highest = f if f.priority_level > highest.priority_level else highest
elif not highest:
highest = f
return highest
class Order:
''' Find files to process in the designated directory '''
def __init__( self, path ):
self.__currentDirList = os.listdir()
self.__currentFileInfo = FilesWithInfo()
self.__nextOrder = ''
self.__done = True
return
def check( self ) -> OrderFile or None:
''' Check if there are orders that need to be processed '''
self.__oldDirList = self.__currentDirList
self.__currentFileInfo = FilesWithInfo( self._getFileInformation( self.__currentDirList ))
if len( self.__currentDirList ) > 0:
self.__nextOrder = self._selectOrder( self.__currentFileInfo )
return self.__nextOrder
else:
return None
def _selectOrder( self, fileInfo: FilesWithInfo ):
''' Select an order to be processed next by applying selection priority criteria '''
prio = fileInfo.priorities if isinstance(fileInfo, FilesWithInfo ) else None
nextOrder = None
if isinstance( prio, PriorityFiles ):
nextOrder = prio.highest
elif isinstance( fileInfo, FilesWithInfo ):
nextOrder = fileInfo.oldest
return nextOrder
def _getFileInformation( self, files: [str] ) -> FilesWithInfo:
''' Run through all the found files and return a Dictionary of OrderFiles '''
ret = []
for name in files:
f_stats = os.stat( name )
newFileInfo = OrderFile( name )
OrderFile.mod_time = f_stats.st_mtime
OrderFile.priority_level = self._getPriorityLevel( name )
ret.append( OrderFile )
return ret
def _getPriorityLevel( self, name: str ) -> int:
''' Find if a filename has priority or not and if so, return the priority level '''
if 'priority' in name:
tmp = name.split( '_' )
locationOfPriority = tmp.index( 'priority' ) + 1
return tmp[ locationOfPriority ]
else:
return 0
