Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Website BUG: Learning>Programming Interface 404 when opened as new Tab
1 REPLY 1
edidos
290 Views, 1 Reply
Whenever I try to open a page of the Programming Interface section of the Learning page as a new tab I get a 404 page instead. This happens on macOS Safari and Chrome.
Tags (3)
1 REPLY 1
marshaltu
in reply to: edidos
I can reproduce the issue. Please use chm file as below as workaround if the issue blocked you. We will pursue a fix.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/fusion-360-api-reference-manual-for-offlin...
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
