Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Way to output geometric data
1 REPLY 1
cregers
124 Views, 1 Reply
I'm working on an arduino project with a mechanism that which requires me to do some complex 3-dimensional geometry. Specifically, I need to find the angle of an output based on the angle of an input. However, this math is 3 dimensional and is not something I can do easily. I was hoping that Fusion would be able to help me out. I assembled the mechanism in Fusion and can see how it moves. Is there a tool I can use to generate a spreadsheet of the input to output values that I am interested in? That way I could make an array in my code and not have to do the complex calculation myself.
1 REPLY 1
kandennti
in reply to: cregers
Hi @cregers .
I don't have a concrete idea of what I'm talking about, so this may be a misunderstanding of the answer.
The Fusion360 API has Vector3D and Matrix3D objects implemented, which are very useful for various operations.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-9cd7639c-97a9-4011-83f0-64694efe76e0
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-b831d9f4-c231-4b9f-9b4d-658614ecdc79
Also, @prainsberry  has a great add-in on Github called "Sheeter" (which I have never used). (I've never used it.)
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/sheeter-google-sheets-connection-for-fusio...
