Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Walk the Path object to get points coordinates.
1 REPLY 1
sr.Lux1nt
273 Views, 1 Reply
I'm willing to create JSON or like file which contains a list of points coordinates generated based on selected path from sketch. I would like to input points distance for script to print coordinates values for each equidistant point on path. Practically I want to create a path for WS2811 LED strip within Fusion modelling/sketch UI and then just print out some application specific mapping file (JSON list) made by script.
The best way I could come up with is to create dummy LED component, patternize it and iterate all components with specific name (e.g. "led_dummy") to print its coordinates (is 'originConstructionPoint' sufficient for my needs?). Though it seems to be not a straight-forward approach
What is the approach I should use? Can I use 'pathPattern' feature somehow to achieve my goal?
Labels (3)
1 REPLY 1
sr.Lux1nt
in reply to: sr.Lux1nt
I happened to find another post with similar problem. It totally suffice my needs.
I can easily manage getting points along selected path directly. The answer for 'points along curve' is provided here:
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/how-to-get-points-along-a-curve/m-p/804409...
