Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Voronoi script not available in new Fusion 360 Mac
2 REPLIES 2
owmekano
310 Views, 2 Replies
I'm trying to add the Voronoi Script in Fusion 360. It shows up in the Mac App Store version but not in the new Autodesk version. Since the Mac App Store version is no longer supported I switched.
In the Mac App Store version the Voronoi.bundle is installed in /Library/Application Support/Autodesk/ApplicationPlugins. Trying to add it via the Scripts and Add-Ins doesn't work as the files are greyed out.
Any solution for this?
2 REPLIES 2
goyals
in reply to: owmekano
In case of MAS add-ins are installed at this location
Library/Containers/com.autodesk.mas.fusion360/Data/Library/Application\ Support/Autodesk/ApplicationPlugins/.
I think If you just copy Voronoi script bundle from above location to
Library/Application\ Support/Autodesk/ApplicationPlugins, it should fix the problem.
Shyam Goyal
Sr. Software Dev. Manager
owmekano
in reply to: goyals
I had it working for a while but since the scripts have moved to the Tools menu, no way to generate a Voronoi script anymore. I already deleted and reinstalled the script anew.
