Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
viewport_var->fit(); is giving a Memory Error 107
1 REPLY 1
tperam
192 Views, 1 Reply
Using c++, following is giving a memory error 107.
Ptr<Viewport> ViewPort;
 ViewPort->fit();
Please respond.
Thurai
Tags (1)
Labels (1)
1 REPLY 1
tperam
in reply to: tperam
the Following from one the API Samples for SketchLines Worked Okay.
 // Fit to window
 Ptr<Viewport> viewPort = app->activeViewport();
 if(!viewPort)
  return false;
 Ptr<Camera> cam = viewPort->camera();
 if(!cam)
  return false;
 cam->isFitView(true);
 viewPort->camera(cam);
Thurai
