Announcements
vertex inside a brepbody
How do i assign the vertex from a square brepbody into a 3dpoint?
ekinsb
The geometry property of the BRepVertex object returns a Point3D object.
Brian Ekins
Mod the Machine blog
I cannot see any function Call in BRepBody class that Returns a BRepVertex Object.
ekinsb
It's unclear to me what you're trying to do.  The Fusion API help has an overview discussing the structure of a model that may help.  If you still have any questions feel free to ask them here.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-1C3FFADB-52C4-49BB-8981-4A448FFE4442
Brian Ekins
i figured vertices was not a 3dPoint, just a BRepVertx.
ekinsb
A vertex is a physical object that represents the connection of two or more edges.  It has a position in space which you can get by using the geometry property of the BRepVertex object.  It also supports other properties that lets you access the edges that it connects.
Brian Ekins
