Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Vector3D angleTo function returning wrong result
2 REPLIES 2
j.han97
220 Views, 2 Replies
Hi all,
Just a very simple problem here. I have defined two vectors, which are the unit vectors in x- and z-directions respectively.
vec_1 = adsk.core.Vector3D.create(1, 0, 0)
vec_2 = adsk.core.Vector3D.create(0, 0, 1)
I expected the angle between these vectors are 90 degrees, which is 0.7854 radian. However, when I used the angleTo function to obtain the result,
vec_1.angleTo(vec_2)
It returned 1.5708 (radian), which is 180 degrees.
Did I miss something or could anyone tell me what is wrong here?
Thank you very much in advance.
Labels (1)
2 REPLIES 2
BrianEkins
in reply to: j.han97
You're just a bit mixed up on the relationship between degrees and radians.  π radians (3.14159) = 180 degrees, so the answer you're getting of 1.5708 radians is 90 degrees.
Brian Ekins
j.han97
in reply to: BrianEkins
Wow, what a stupid mistake from me. Thank you so much Brian.
