Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
variable parameters
3 REPLIES 3
maximiliandoerfler1999
91 Views, 3 Replies
variable parameters
is it possible to create an parameter with variable values?
For example something like
1. x=1
2. x=(x+1)
I would like to have borings that are becoming, larger while the space between them also increases.
regards
3 REPLIES 3
No, you can't define a variable value with circular reference to itself.
If you provide a better explanation of what you want, I'd be happy to help you out.
Jorge Jaramillo
Software Engineer
Thanks for the reply.
As mentioned, i have a bunch of borings that are in a row. They're supposed
to become bigger with each stepp, while the wall thickness between the
bores remains the same.
Maybe an image of you want could help to clarify your idea.
