Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Using SplitBody Feature parallel to xYConstructionPlane
2 REPLIES 2
rocco.mayr
152 Views, 2 Replies
I want to split a body using the SplitBody Feature. But I want to make the split with a plane that is parallel to the xYConstructionPlane 5mm over it.
What to I have to use instead of 'rootComp.xYConstructionPlane'?
# Create SplitBodyFeatureInput
  splitBodyFeats = rootComp.features.splitBodyFeatures
  splitBodyInput = splitBodyFeats.createInput(body, rootComp.xZConstructionPlane, True)
2 REPLIES 2
rocco.mayr
in reply to: rocco.mayr
Well a workaround would be to move the body downwards so that the split line is in the xYPlane. But maybe someone could show how to create a plane for the SplitBody Feature.
rocco.mayr
One solution is to create an Offset Plane
Have a look here:
Create Plane from sketch profile
