Using findBRepByUsingPoint
pludikar
pludikar
I'm trying to use the findBRepByUsingPoint method found in component:
if I have a face entity:
face.assemblyContext.component.findBRepByUsingPoint(face.pointOnFace, adsk.fusion.BRepEntityTypes.BRepFaceEntityType)  >>  returns an objectCollection
but
face.assemblyContext.component.findBRepByUsingPoint(face.pointOnFace, adsk.fusion.BRepEntityTypes.BRepFaceEntityType).count returns 0 - meaning it hasn't found anything.
I would have expected it to return count of 1.
Am I missing something?
Peter
I'm not an expert, but I know enough to be very, very dangerous.
Life long R&D Engineer (retired after 30+ years in Military Communications, Aerospace Robotics and Transport Automation).
pludikar
I think pressing the send button, is cathartic, makes me relax and when I'm relaxed I come up with solutions.
The issue is, and this seems to be the way F360 works, is when working and modifying Occurrences, you MUST be working with the NativeObject.  I had assumed that you had to be working with the Occurrence and, because everything is in same world coordinate space, and the occurrences would take care of the rest - Not so!!
The component referred to by:
 is actually in the nativeObject space.  So
face.pointOnFace
the resulting coordinates are in the wrong place
The solution:
face.nativeObject.pointOnFace
and now
face.assemblyContext.component.findBRepByUsingPoint(face.nativeObject.pointOnFace, adsk.fusion.BRepEntityTypes.BRepFaceEntityType).count >> returns 1
Hope that helps anyone else who has come across the same issue
Peter
