Announcements
User parameters and sliders are connected, but are always reset
542002010815
Observer
542002010815
Observer
Observer
I would like to link the slider to a user parameter so that the value of the slider can control the user parameter. But every time after modifying or creating a user parameter, the interface goes back to the very beginning, as if it hasn't changed, which it does, just for a moment. You can watch the attached video。
import adsk.core, adsk.fusion, traceback
_app = None
_ui = None
_handlers = []
_doc = None
_design = None
slider_value = 0.0
length_param = None
def create_or_update_length_parameter():
    try:
        global length_param
        length_param = _design.userParameters.itemByName("Length")
        if length_param:
            _design.userParameters.itemByName("Length").expression = str(slider_value)
            _ui.messageBox('Length parameter updated to: {} cm'.format(length_param.value))
            if not _doc.isSaved:
                    _doc.saveAs("ceshi", "This is the first save description.")
            else:
                _doc.save("This is an update description.")
        else:
            length_value = 10.0
            lengthValue = adsk.core.ValueInput.createByReal(length_value)
            lengthparam = _design.userParameters.add("Length", lengthValue, "cm", " ")
            _ui.messageBox('Length parameter created with value: {} cm'.format(lengthparam.value))
    except Exception as e:
        _ui.messageBox('Failed to create or update Length parameter:\n{}'.format(e))
class MyCommandDestroyHandler(adsk.core.CommandEventHandler😞
    def __init__(self😞
        super().__init__()
    def notify(self, args😞
        try:
            adsk.terminate()
        except:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
class MyInputChangedHandler(adsk.core.InputChangedEventHandler😞
    def __init__(self😞
        super().__init__()
        try:
            if args.input.id == "slider_controller":
                global slider_value
                slider_input = adsk.core.FloatSliderCommandInput.cast(args.input)
                slider_value = slider_input.valueOne
                _ui.messageBox('Slider value changed to: {}'.format(slider_value))
                _ui.messageBox('Length parameter value updated to:')
        except:
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler😞
    def __init__(self😞
        super().__init__()
        try:
            cmd = adsk.core.Command.cast(args.command)
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            _handlers.append(onDestroy)
            inputs = cmd.commandInputs
            slider_input = inputs.addFloatSliderCommandInput("slider_controller", "Slider", "cm", 0, 10.0)
            slider_input.valueOne = slider_value
            onInputChanged = MyInputChangedHandler()
            cmd.inputChanged.add(onInputChanged)
            _handlers.append(onInputChanged)
        except:
def run(context😞
    try:
        global _app, _ui, _design, slider_value, length_param,_doc
        slider_value = 5.0
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        _design = _app.activeProduct
        _doc = _app.activeDocument
        cmdDef = _ui.commandDefinitions.itemById('sliderCommandSample')
        if not cmdDef:
            cmdDef = _ui.commandDefinitions.addButtonDefinition('sliderCommandSample', 'Slider Command Sample', 'Sample to demonstrate slider input.')
        onCommandCreated = MyCommandCreatedHandler()
        cmdDef.commandCreated.add(onCommandCreated)
        _handlers.append(onCommandCreated)
        cmdDef.execute()
        adsk.autoTerminate(False)
    except:
        if _ui:
Jorge_Jaramillo
InputChanged event is mainly used to update command inputs inside the command being executed, not to make changes to the model.
You might need to use ExecutePreview event instead of InputChanged event in order to keep the changes to the model while the command is being executed.
This topic from the API documentation explain the use of the ExecutePreview and also take especial consideration of using the isValidResult property from the CommandEventArgs passed in to the event:
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-3922697A-7BF1-4799-9A5B-C8539DF57051#Execute...
Jorge Jaramillo
542002010815
Observer
Observer
Thank You!!
