Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Unstitch return value
3 REPLIES 3
imajar
193 Views, 3 Replies
In the script below I create a simple cube, then I unstitch that cube into its faces.
In the gui, this all works as it should, but line 36, "unstitchedbox=unstitch.add(entities)" returns null despite the UI showing the unstitched faces, shouldn't the variable "unstichedbox" return an unstitch feature containing the newly unstitched faces?  Or what am I doing wrong here?  (I am having the same problem with the stitch feature successfully stitching surfaces into a solid body but returning null).
Thank You,
import adsk.core, adsk.fusion, adsk.cam, traceback
def CreateBox():
    # Get TemporaryBRepManager
    tempBrepMgr = adsk.fusion.TemporaryBRepManager.get()
    centerPoint = adsk.core.Point3D.create(0.0, 10.0, 0.0);
    lengthDir = adsk.core.Vector3D.create(1.0, 0.0, 0.0)
    widthDir = adsk.core.Vector3D.create(0.0, 1.0, 0.0)
    orientedBoundingBox3D = adsk.core.OrientedBoundingBox3D.create(centerPoint, lengthDir, widthDir, 5.0, 6.0, 2.0)
    # Create box
    box = tempBrepMgr.createBox(orientedBoundingBox3D)
    return box
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        design.designType = adsk.fusion.DesignTypes.DirectDesignType
        rootComp = design.rootComponent
        features = rootComp.features
        bodies = rootComp.bRepBodies
        # Create a temporary solid box
        box = CreateBox()
        newbox=bodies.add(box)
        #Unstitch the box
        unstitch=features.unstitchFeatures
        entities=adsk.core.ObjectCollection.create()
        entities.add(newbox)
        unstitchedbox=unstitch.add(entities) #unstitchedbox is null?
        print("unstitchedbox Type: ",unstitchedbox.classType())
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
3 REPLIES 3
kandennti
in reply to: imajar
Hi ajarrett.
I don't know why but unstitch doesn't seem to work with DirectDesignType.
Temporarily change to ParametricDesignType and unstitch.
Change to DirectDesignType again
Then what about?
def run(context):
    ui = None
    try:
        box = CreateBox()
        #ParametricDesignType
        design.designType = adsk.fusion.DesignTypes.ParametricDesignType #this
        #Unstitch the box
        #DirectDesignType
        design.designType = adsk.fusion.DesignTypes.DirectDesignType #this
    except:
        if ui:
imajar
in reply to: kandennti
That works for me.
Digging in a bit more, it looks like there may be other features that don't work in ParametricDesignType.  After a successful unstitch, If I did stitch.bodies.count in parametric design it returns 0, in DirectDesignType it returns 1. . .
Anyway, not sure if this is a bug or if stitch is not supposed to be used in ParametricDesignType designs?
Aaron Jarrett, PE
LinkedIn
Life is Good.
zxynine
in reply to: imajar
I know this thread is pretty old, but I am currently running into the same issue with stitchFeatures. Im trying to stitch regardless of design type and im doing it on execute preview so I cannot quickly switch design types. Have any of you found a better solution? I cannot even access the bodies attr because the stitchFeature is None, yet the faces still get stitched into a body (A return of None should mean it failed, yet it hasn't.).
