Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Unlink sheeter
2 REPLIES 2
brad.bylls
354 Views, 2 Replies
Unlink sheeter
I have created a cap screw file with a link to a sheeter spread sheet.
This lets me create any imperial size cap screw with a sub-body that has clearance and tap drill sizes.
The sub-body is used to subtract from the components the clearance holes, counterbore and tap drill hole for that size screw.
Can I unlink the spreadsheet once I have the screw that I need so I can create another screw of a different size without it affecting the first screw that I made.
Sheeter works great, but when I create the new screw and sync to the spreadsheet, the first screw changes also.
Brad Bylls
2 REPLIES 2
OceanHydroAU
in reply to: brad.bylls
Very interesting - can you share an example?  I'd like to check out this behaviour just for interest, and might be able to find you an answer while I do!
brad.bylls
in reply to: OceanHydroAU
I used it to create a screw in an assembly.
But when I did another screw of a different size, the first screw changed
to the new size.
Brad Bylls
