Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Unexpected error while reinstalling
3 REPLIES 3
rodrigoyanezlozano
251 Views, 3 Replies
I just downloaded Fusion 360 and started using it but i realized that it wouldnt let me log in to my account and i wasnt able to save my designs, so i tried to fix the issue and somehow i managed to erase some files from this directory:
C:\Users\name\AppData\Local\Autodesk
and i completely made the problem bigger cause i couldnt uninstall the software due to missing files.
An now i try to reinstall Fusion and i get an unexpected error that says:
Please attach the file C:\Users\name\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
And i have no idea how to fix the problem.
Capture.PNGHELP!
3 REPLIES 3
I've already done all this and still wont uninstall
Manually clear remaining program files:
          1. Launch Windows Explorer.
          2. Navigate to: C:\Users\<username>\AppData\Local\Autodesk
          3. Delete the following folders:
              - Autodesk Fusion 360 (if present)
              - Web Services
              - Webdeploy (if present)
              - production (if present)
              - Neutron Platform (if present)
          4. Next, navigate to: C:\Users\<username>\AppData\Local\Autodesk\Common
           5. Delete the following folders:
              - Material Library
              - DB Manager
              - Exchange Archives
          6. Next, navigate to: C:\Users\<username>\AppData\Local\Temp
          7. Delete the following folders:
              - Autodesk
              - proteinrun
              - Neutron
          8. Now navigate to C:\Users\<username>\AppData\Roaming\Autodesk
          9. Ensure the following folders have been deleted. If they haven’t, manually delete them.
              - MC3
              - Neutron Platform
              - NINVFUS
              - Synergy
         10. Next navigate to C:\Program Data\Autodesk
         11. Ensure the following folders have been deleted. If they haven’t, manually delete them.
             - MC3
             - Neutron
             - NINVFUS
svelez
in reply to: rodrigoyanezlozano
Hello Rodrigo,
The log file you posted seems to indicate difficulty establishing a connection to our servers, and the troubleshooting steps you found do not usually address that issue.
It's odd, in fact, that an install completed earlier, but now you are seeing this issue.   Are you connected to a different network now (at home instead of at work, or vice versa?) if so, can you try again from the original location?
If that does not help, or is not an option, one other thing that has helped users with similar issues in the past is to make sure the computer is current on all windows updates.
Also, I will PM you a link that can be used to help us gather more information on your connection.
Steven
svelez
I cannot send you a PM since that feature is disabled on your account. Please contact me with an e-mail address I can send the information to.
Steven
