Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
UnExpected Bounding Box results
4 REPLIES 4
saurabh.verma
281 Views, 4 Replies
I am trying to get the bounding box by selecting a circle of a butterfly type control valve  through the code. and getting unexpected results .
The geometry is itself far away from the origin but the bounding box values comes with including the origin.
This is code written below explaining how i am getting  bounding boxing for Inlet.
Ptr<BRepEdge> inletEdge = rotationInput.InletEdge;
Ptr<BRepCoEdges> inletCoEdges = inletEdge->coEdges();
Ptr<BoundingBox3D> InletBBox = BoundingBox3D::create(Point3D::create(), Point3D::create());
for (size_t i = 0; i < inletCoEdges->count(); i++)
Ptr<BRepCoEdge> inletCoEdge = inletCoEdges->item(i);
Ptr<BRepLoop> loop = inletCoEdge->loop();
InletBBox->combine(loop->boundingBox());
original results
min x= -10, min y= -10, min z= 0,
max x= 10 max y= 10, max z=36.25
wherein we expect different values for z.
4 REPLIES 4
ekinsb
in reply to: saurabh.verma
A CoEdge is a 2D object.  It represents an edge in the parametric space of a surface so the Z will always be 0 and the X and Y will be in the parameter space of the surface.  If you want 3D information you need to use the BRepEdge object.  What exactly is it that you're trying to do?
Brian Ekins
Mod the Machine blog
saurabh.verma
in reply to: ekinsb
Replying on behalf of saurabh verma
Yes,I am actually trying to get the bounding box all coordinates values and
centroid of that circle, by selecting a circle on the geometry.
Yes for this case BRepEdge would suffice my purpose.Any sample of getting
bounding box and centroid using BRepEdge would be very helpful.
Prakhar Nigam| Member Of Technical Staff
*Centre for Computational Technologies - CCTech*
1 Akshay Residency | 50 Anand Park | Aundh | Pune | 411007 | India
Ph: +91 20 40098381/82 | M: +7768942662 | www.cctech.co.in
*CCTech** - "**Transforming human life by democratization of technology**"*
saurabh.verma
in reply to: ekinsb
ekinsb
There's been an oversight in the API design and getting the bounding box from an edge is not currently possible. I've written some code below that demonstrates a workaround to use another function and calculating the bounding box from it.  I've also added an issue into the API backlog to support getting the bounding box from an edge so it will be available in the future.
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        des = adsk.fusion.Design.cast(app.activeProduct)
        root = des.rootComponent
        edge = adsk.fusion.BRepEdge.cast(ui.selectEntity('Select an edge.', 'Edges').entity)
        # Because the boundingBox property is missing on the BRepEdge object, calculate
        # it ourselves.
        curveEval = edge.evaluator
        (returnValue, startParameter, endParameter) = curveEval.getParameterExtents()
        (returnValue, coords) = curveEval.getStrokes(startParameter, endParameter, 0.001)
        minVal = coords[0].copy()
        maxVal = coords[0].copy()
        for i in range(1, len(coords)):
            if coords[i].x < minVal.x:
                minVal.x = coords[i].x
            if coords[i].y < minVal.y:
                minVal.y = coords[i].y
            if coords[i].z < minVal.z:
                minVal.z = coords[i].z
            if coords[i].x > maxVal.x:
                maxVal.x = coords[i].x
            if coords[i].y > maxVal.y:
                maxVal.y = coords[i].y
            if coords[i].z > maxVal.z:
                maxVal.z = coords[i].z
        ui.messageBox('Range:\n   Min:' + str(minVal.asArray()) +
                      '\n   Max:' + str(maxVal.asArray()))
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
