Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Uncable click the ok button whitout Destroying
1 REPLY 1
ho-kou
132 Views, 1 Reply
Hi everyone,
when click the panel' ok button, command is Destroyed and panel is hidded.
how can whitout Destroying when click the ok button.
thanks for your reply.
1 REPLY 1
BrianEkins
in reply to: ho-kou
It's not possible. Clicking the OK button executes the command, which results in the execute event being fired and whatever is done in that event being wrapped into a transaction that can be undone. The final step is that Fusion takes down the dialog because the command is over.
It's possible to restart your command to cause the dialog to be displayed again.
Brian Ekins
