Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Unable to set appearance of loaded STL
0 REPLIES 0
Message 1 of 1
tomveuskens
227 Views, 0 Replies
Setting the appearance of a loaded STL file through the API doesn't change the visual appearance, even with the minimal example shown below (based on a sample provided in the docs). This functionality used to work in the past.
#Author-
#Description-
import adsk.core, adsk.fusion, traceback
import os.path
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        # Create a document
        doc = app.documents.add(adsk.core.DocumentTypes.FusionDesignDocumentType)
        product = app.activeProduct
        design = adsk.fusion.Design.cast(product)
        # Get the root component
        rootComp = design.rootComponent
        # Create a sub component under root component
        occs = rootComp.occurrences
        transform = adsk.core.Matrix3D.create()
        subOcc = occs.addNewComponent(transform)
        # Insert a stl mesh body in the sub component
        subComp = subOcc.component
        meshBodies = subComp.meshBodies
        scriptDir = os.path.dirname(os.path.realpath(__file__))
        stlFilePath = os.path.join(scriptDir, 'APIMeshFacetColors.stl')
        meshBodies.add(stlFilePath, adsk.fusion.MeshUnits.InchMeshUnit)
        stlMeshBody = meshBodies.item(0)
        # Get and set mesh body appearance
        print('Get and set meshbody appearance.')
        print(stlMeshBody.appearance.name)
        appearanceLib = app.materialLibraries.itemByName('Fusion 360 Appearance Library')
        appearance = appearanceLib.appearances.itemByName('Cherry')
        stlMeshBody.appearance = appearance
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Tags (3)
0 REPLIES 0
