Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Unable to accurately export gear sketch after using spur script
1 REPLY 1
lj_0211
208 Views, 1 Reply
Hello this is my first post to the forums. I have a problem where I would like to export a sketch of a gear i've made in Fusion over to LibreCad, however when I go on the timeline and edit the sketch, I don't see the teeth of the gears anywhere. This is a problem as I'd like to export all my other gears into LibreCad if possible and would prefer to not remake all the gears' sketches by hand.
I've attached my gear below, thanks in advance.
Tags (2)
1 REPLY 1
tykapl.breuil
in reply to: lj_0211
I'm not sure what you mean as the teeths were never sketches in the first place, one teeth was sketched (Sketch2), then extruded and then the circular pattern command was used to make the teeths go all around.
I'm not sure what you want to do but projecting your gear onto a sketch to get its outline or using the circular pattern command on sketch 2 might bring the results you want.
