Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
UI SliderCommandInput is still enabled for user interaction despite isEnabled is set to False
2 REPLIES 2
wh6Q9NU
176 Views, 2 Replies
I would expect a SliderCommandInput to be disabled for user interaction, but after setting isEnabled to false the label is greyed out but the slider is still accessible.
integerSliderInput = inputs.addIntegerSliderCommandInput('count', 'Joints', 1, 10, False)
integerSliderInput.isEnabled = False
from docs:
in ui - label is greyed out but slider is still accessible for user interaction:
Labels (1)
  • UI
2 REPLIES 2
OceanHydroAU
in reply to: wh6Q9NU
You need to put "Bug Report:" in the title of your posts (and probably also the category/topic or whatever those other 2 boxes at the end are), and post them into the "Fusion 360 Support" forum for these things.
The programming team workflow is to check that forum for those postings and action them 🙂
goyals
Created ticket FUS-78146 to track this. Thanks for posting this issue.
Shyam Goyal
Sr. Software Dev. Manager
