Announcements
Troubleshooting Additive Manufacturing Implementation in Fusion 360 using C++
subhashraj8210
Observer
subhashraj8210
Observer
Observer
I'm exploring additive Manufacturing in fusion 360 using C++. In the fusion's documentation I got a sample program in Python as below -
import adsk.core, adsk.fusion, adsk.cam, traceback, tempfile, time
from . import commands
from .lib import fusion360utils as futil
app = adsk.core.Application.get()
ui  = app.userInterface
def showMessage(message):
    app.log(message)
# Create an additive setup.
def createAdditiveSetup(models: list[adsk.fusion.Occurrence], cam: adsk.cam.CAM):
    setups = cam.setups
    input = setups.createInput(adsk.cam.OperationTypes.AdditiveOperation)
    input.models = models
    input.name = 'AdditiveSetup'
    camManager = adsk.cam.CAMManager.get()
    libraryManager = camManager.libraryManager
    printSettingLibrary = libraryManager.printSettingLibrary
    machineLibrary = libraryManager.machineLibrary
    printSetting = None
    machine = None
    if True:
        # URL-structure browsing
        printSettingUrl = printSettingLibrary.urlByLocation(adsk.cam.LibraryLocations.Fusion360LibraryLocation) ## .Fusion360LibraryLocation vs .LocalLibraryLocation etc.
        printSettings = printSettingLibrary.childPrintSettings(printSettingUrl)
        machineUrl = machineLibrary.urlByLocation(adsk.cam.LibraryLocations.Fusion360LibraryLocation) ## .Fusion360LibraryLocation vs .LocalLibraryLocation etc.
        machines = machineLibrary.childMachines(machineUrl)
        for ps in printSettings:
            if ps.name ==  "PLA (Direct Drive)": #print setting name from fusions library
                printSetting = ps
                break
        for machine in machines: #model name from fusions library -- Example: "Generic FFF Machine"
            if machine.model ==  "i3 MK3S+":
                machine = machine
                break
    input.machine = machine
    input.printSetting= printSetting
    setup = setups.add(input)
    return setup
# Given an occurrence, this finds all child occurrences that contain either a
# B-Rep or Mesh body. It is recursive, so it will find all occurrences at all levels.
def getValidOccurrences(occurrence: adsk.fusion.Occurrence) -> list[adsk.fusion.Occurrence]:
    result = []
    for childOcc in occurrence.childOccurrences:
        if (childOcc.bRepBodies.count + childOcc.component.meshBodies.count  > 0):
            result.append(childOcc)
        result.extend(getValidOccurrences(childOcc))
    return result
def run(context):
    try:
        # This will run the start function in each of your commands as defined in commands/__init__.py
        #commands.start()
        # Make sure the TEXT COMMAND palette is visible.
        textPalette = ui.palettes.itemById('TextCommands')
        if not textPalette.isVisible:
            textPalette.isVisible = True
            adsk.doEvents()
        doc = app.activeDocument
        products = doc.products
        # Make
        camWS = ui.workspaces.itemById('CAMEnvironment')
        camWS.activate()
        cam = adsk.cam.CAM.cast(products.itemByProductType("CAMProductType"))
        # Design creation
        designWS = ui.workspaces.itemById('FusionSolidEnvironment')
        designWS.activate()
        design = adsk.fusion.Design.cast(products.itemByProductType("DesignProductType"))
        camWS.activate()
        showMessage('=============================================')
        showMessage('Creating Manufacturing Model...')
        manufacturingModels = cam.manufacturingModels
        mmInput = manufacturingModels.createInput()
        mmInput.name = "My Manufacturing Model - FFF"
        manufacturingModel = manufacturingModels.add(mmInput)
        showMessage('Getting occurrences...')
        occs = getValidOccurrences(manufacturingModel.occurrence)
        if len(occs) == 0:
            ui.messageBox('No component has been added to the scene.')
            return
        showMessage('Creating arrange operation...')
        setup = createAdditiveSetup(occs, cam)
        # Define and create the arrange operation.
        operationInput = setup.operations.createInput('additive_arrange')
        arrange = setup.operations.add(operationInput)
        parameter: adsk.cam.StringParameterValue = arrange.parameters.itemByName("arrange_arrangement_type").value
        parameter.value = 'Pack2D'
        # Specify the values to control the arrangement. All length units are centimeters.
        parameter: adsk.cam.FloatParameterValue = arrange.parameters.itemByName("arrange_platform_clearance").value
        parameter.value = 0
        parameter: adsk.cam.FloatParameterValue = arrange.parameters.itemByName("arrange_frame_width").value
        parameter.value = 0.5
        parameter: adsk.cam.FloatParameterValue = arrange.parameters.itemByName("arrange_ceiling_clearance").value
        parameter: adsk.cam.FloatParameterValue = arrange.parameters.itemByName("arrange_object_spacing").value
        parameter.value = 1
        future = cam.generateToolpath(arrange)
        while (future.isGenerationCompleted == False):
            time.sleep(0.5)
        # Create the automatic orientation operations for each occurrence.
        for occ in occs:
            showMessage(f'Defining orientation for occurrence "{occ.name}" ...')
            operationInput = setup.operations.createInput('automatic_orientation')
            #operationInput.isAutoCalculating = False
            orientationTarget = operationInput.parameters.itemByName('optimizeOrientationTarget')
            orientationTarget.value.value = [occ]
            operationInput.displayName = 'Automatic Orientation: ' + occ.name
            #global orientation
            orientation = setup.operations.add(operationInput)
            parameter: adsk.cam.FloatParameterValue = orientation.parameters.itemByName("optimizeOrientationSmallestRotation").value
            parameter.value = 180 #angle units are always degrees
            parameter: adsk.cam.BooleanParameterValue = orientation.parameters.itemByName("optimizeOrientationUsePreciseCalculation").value
            parameter.value = True #capitilize
            parameter: adsk.cam.FloatParameterValue = orientation.parameters.itemByName("optimizeOrientationCriticalAngle").value
            parameter.value = 45 #angle units are always degrees
            parameter: adsk.cam.FloatParameterValue = orientation.parameters.itemByName("optimizeOrientationDistanceToPlatform").value
            parameter.value = 0 #units are always cm
            parameter: adsk.cam.BooleanParameterValue = orientation.parameters.itemByName("optimizeOrientationMoveToCenter").value
            parameter: adsk.cam.FloatParameterValue = orientation.parameters.itemByName("optimizeOrientationFrameWidth").value
            parameter.value = 0.5 #units are always cm
            parameter: adsk.cam.FloatParameterValue = orientation.parameters.itemByName("optimizeOrientationCeilingClearance").value
            parameter: adsk.cam.ChoiceParameterValue = orientation.parameters.itemByName("optimizeOrientationRankingSupportVolume").value
            parameter.value = '10' #take the number from dialog with its quotes
            parameter: adsk.cam.ChoiceParameterValue = orientation.parameters.itemByName("optimizeOrientationRankingSupportArea").value
            parameter.value = '0' #take the number from dialog with its quotes
            parameter: adsk.cam.ChoiceParameterValue = orientation.parameters.itemByName("optimizeOrientationRankingBoundingBoxVolume").value
            parameter.value = '2' #take the number from dialog with its quotes
            parameter: adsk.cam.ChoiceParameterValue = orientation.parameters.itemByName("optimizeOrientationRankingPartHeight").value
            parameter.value = '6' #take the number from dialog with its quotes
            parameter: adsk.cam.ChoiceParameterValue = orientation.parameters.itemByName("optimizeOrientationRankingCOGHeight").value
            showMessage('Generating orientation...')
            future = cam.generateToolpath(orientation)
                time.sleep(0.5)
            generatedResults = orientation.generatedDataCollection
            castPref = None
            firstResult = None
            primary = generatedResults.itemByIdentifier(adsk.cam.GeneratedDataType.OptimizedOrientationGeneratedDataType)
            if isinstance(primary, adsk.cam.OptimizedOrientationResults):
                castPref: adsk.cam.OptimizedOrientationResults = primary
                firstResult = castPref.item(0)
            castPref.currentOrientationResult = firstResult
            showMessage('Generating arrange...')
                time.sleep(0.5)
            showMessage('Generating supports...')
            supportInput = setup.operations.createInput('solid_volume_support')
            volumeSupport = setup.operations.add(supportInput)
            supportParam = volumeSupport.parameters.itemByName('supportTarget')
            supportParam.value.value = occs
            future = cam.generateToolpath(volumeSupport)
                time.sleep(0.5)
            if volumeSupport.hasError:
                volumeSupport.deleteMe()
            showMessage('Generating toolpath...')
            toolpath = None
            i = 0
            for i in range(setup.operations.count):
                op = setup.operations.item(i)
                if (op.strategy == 'additive_buildstyle'):
                    toolpath = op
                    break
            if (toolpath == None):
                return
            future = cam.generateToolpath(toolpath)
                time.sleep(1.0)
            app.activeViewport.fit()
            # Start the toolpath simulation command.
            # app.executeTextCommand('NaNeuCAMUI.AdditiveSimulateCmd')
            showMessage('Finished.')
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
        adsk.terminate()
        futil.handle_error('run')
        # end
def stop(context):
    try:
        # Remove all of the event handlers your app has created
        futil.clear_handlers()
        commands.stop()
    except:
        futil.handle_error('stop')
I changed these code in c++ as below -
#include <Core/CoreAll.h>
#include <Fusion/FusionAll.h>
#include <Cam/CamAll.h>
#include <vector>
#include <iostream>
#include <string>
#include <thread>
#define M_PI 3.14
using namespace adsk::core;
using namespace adsk::fusion;
using namespace adsk::cam;
Ptr<Application> app;
Ptr<UserInterface> ui;
/* Create Additive setup*/
Ptr<Setup> createAdditiveSetup(std::vector<Ptr<Occurrence>> models, Ptr<CAM>& cam) {
    Ptr<Setups> setups = cam->setups();
    Ptr<SetupInput> setupInput = setups->createInput(OperationTypes::AdditiveOperation);
    std::vector<Ptr<Base>> _models;
    for (size_t i = 0; i < models.size(); ++i) {
        Ptr<Occurrence> item = models[i];
        Ptr<Base> _occur = item->cast<Base>();
        if (!_occur) {
            ui->messageBox("occurrence is not type cast into Base !");
            return false;
        _models.push_back(_occur);
    bool modelsFlag = setupInput->models(_models);
    if (modelsFlag == false)
        ui->messageBox("Models are not setup into setupInput");
    setupInput->name("AdditiveSetup");
    Ptr<CAMManager> camManager = CAMManager::get();
    Ptr<CAMLibraryManager> libraryManager = camManager->libraryManager();
    Ptr<PrintSettingLibrary> printSettingLibrary = libraryManager->printSettingLibrary();
    Ptr<MachineLibrary> machineLibrary = libraryManager->machineLibrary();
    Ptr<PrintSetting> printSetting = nullptr;
    Ptr<Machine> machine = nullptr;
    /* finding the desired print setting and machine */
    Ptr<URL> printSettingUrl = printSettingLibrary->urlByLocation(LibraryLocations::Fusion360LibraryLocation);
    std::vector<Ptr<PrintSetting>> printSettings = printSettingLibrary->childPrintSettings(printSettingUrl);
    Ptr<URL> machineUrl = machineLibrary->urlByLocation(LibraryLocations::Fusion360LibraryLocation);
    std::vector<Ptr<Machine>> machines = machineLibrary->childMachines(machineUrl);
    for (auto ps : printSettings) {
        if (ps->name() == "PLA (Direct Drive)") {
            printSetting = ps;
            break;
    for (auto mach : machines) {
        if (mach->model() == "i3 MK3S+") {
            machine = mach;
            break;
    setupInput->machine(machine);
    setupInput->printSetting(printSetting);
    Ptr<Setup> setup = setups->add(setupInput);
    return setup;
std::vector<Ptr<Occurrence>> getValidOccurrences(Ptr<Occurrence> occurrence) {
    std::vector<Ptr<Occurrence>> result;
    // Iterate through child occurrences
    Ptr<OccurrenceList> childOccurrences = occurrence->childOccurrences();
    for (size_t i = 0; i < childOccurrences->count(); ++i) {
        Ptr<Occurrence> childOccurrence = childOccurrences->item(i);
        // Check if the child occurrence has valid bodies
        if (childOccurrence->bRepBodies()->count() + childOccurrence->component()->meshBodies()->count() > 0) {
            result.push_back(childOccurrence);
        // Recursively call the function for nested occurrences
        std::vector<Ptr<Occurrence>> nestedOccurrences = getValidOccurrences(childOccurrence);
        result.insert(result.end(), nestedOccurrences.begin(), nestedOccurrences.end());
    return result;
extern "C" XI_EXPORT bool run(const char* context)
    app = Application::get();
    if (!app)
        return false;
    ui = app->userInterface();
    if (!ui)
        return false;
    // get current document
    Ptr<Document> doc = app->activeDocument();
    Ptr<Products> products = doc->products();
    // switch to the manufacture space
    Ptr<Workspace> camWS = ui->workspaces()->itemById("CAMEnvironment");
    camWS->activate();
    // get the CAM product
    Ptr<CAM> cam = products->itemByProductType("CAMProductType")->cast<CAM>();
    // Design creation
    Ptr<Workspace> designWS = ui->workspaces()->itemById("FusionSolidEnvironment");
    designWS->activate();
    Ptr<Design> design = products->itemByProductType("DesignProductType")->cast<Design>();
    camWS->activate();
    // creating Manufacturing Model...
    Ptr<ManufacturingModels> manufacturingModels = cam->manufacturingModels();
    Ptr< ManufacturingModelInput> mmInput = manufacturingModels->createInput();
    mmInput->name("My Manufacturing Model - FFF");
    Ptr<ManufacturingModel> manufacturingModel = manufacturingModels->add(mmInput);
    /* getting occurence */
    std::vector<Ptr<Occurrence>> occs = getValidOccurrences(manufacturingModel->occurrence());
    if (occs.size() == 0) {
        ui->messageBox("No component has been added to the scene");
        return true;
    /* Creating arrange operation....*/
    Ptr<Setup> setup = createAdditiveSetup(occs, cam);
    /* define and create the arrange operation*/
    Ptr<OperationInput> operationInput = setup->operations()->createInput("additive_arrange");
    Ptr<Operation> arrange = setup->operations()->add(operationInput);
    Ptr<ChoiceParameterValue> stringparameter = arrange->parameters()->itemByName("arrange_arrangement_type")->value()->cast<ChoiceParameterValue>();
    if(stringparameter != nullptr)
        if (!stringparameter->value("Pack2D")) {
            ui->messageBox("arrange_arrangement_type failed");
            return true;
    Ptr<FloatParameterValue> floatParameter = arrange->parameters()->itemByName("arrange_platform_clearance")->value()->cast<FloatParameterValue>();
    if(floatParameter != nullptr)
        if (!floatParameter->value(0)) {
            ui->messageBox("arrange_platform_clearance failed !");
            return true;
    Ptr<FloatParameterValue> floatParameter2 = arrange->parameters()->itemByName("arrange_frame_width")->value()->cast<FloatParameterValue>();
    if(floatParameter2 != nullptr)
        if (!floatParameter2->value(0.5)) {
            ui->messageBox("arrange_frame_width failed !");
            return true;
    Ptr<FloatParameterValue> floatParameter3 = arrange->parameters()->itemByName("arrange_ceiling_clearance")->value()->cast<FloatParameterValue>();
    if (floatParameter3 != nullptr)
        if (!floatParameter->value(0.5)) {
            ui->messageBox("arrange_ceiling_clearance failed !");
            return true;
    Ptr<FloatParameterValue> floatParameter4 = arrange->parameters()->itemByName("arrange_object_spacing")->value()->cast<FloatParameterValue>();
    if(floatParameter4 != nullptr)
        if (!floatParameter->value(1)) {
            ui->messageBox("arrange_object_spacing failed !");
            return true;
    Ptr<GenerateToolpathFuture> future = cam->generateToolpath(arrange);
    while (future->isGenerationCompleted() == false)
        std::this_thread::sleep_for(std::chrono::milliseconds(500));
    /*create the automatic orientation operations for each occurrence*/
    for (Ptr<Occurrence> occ : occs) {
        operationInput = setup->operations()->createInput("automatic_orientation");
        //operationInput->isAutoCalculating(false);
        Ptr<CAMParameter> orientationTarget = operationInput->parameters()->itemByName("optimizeOrientationTarget");
        Ptr<CadObjectParameterValue> cadObjectParameterValue = orientationTarget->value()->cast<CadObjectParameterValue>();
        if (!cadObjectParameterValue) {
            ui->messageBox("optimizeOrientationTarget failed !");
            return true;
        //orientationTarget.value.value = [occ]
        std::vector<Ptr<Base>> occurrence;
        Ptr<Occurrence> oc = occ;
        Ptr<Base> item = oc->cast<Base>();
        occurrence.push_back(item);
        if (!cadObjectParameterValue->value(occurrence)) {
            ui->messageBox("Occurrence is not inserted for orientation");
            return true;
        operationInput->displayName("Automatic Orientation: " + occ->name());
        /*global orientation*/
        Ptr<Operation> orientation = setup->operations()->add(operationInput);
        if (orientation != nullptr) {
            Ptr<FloatParameterValue> parameter = orientation->parameters()->itemByName("optimizeOrientationSmallestRotation")->value();
            if (!parameter->value(180)) { // angle units are always degrees
                ui->messageBox("failed for optmize orientation smallest rotation");
            Ptr<BooleanParameterValue> booleanparameter = orientation->parameters()->itemByName("optimizeOrientationUsePreciseCalculation")->value()->cast<BooleanParameterValue>();
            if(booleanparameter != nullptr)
                if (!booleanparameter->value(true)) {
                    ui->messageBox("optimizeOrientationUsePreciseCalculation failed !");
                    return true;
            parameter = orientation->parameters()->itemByName("optimizeOrientationCriticalAngle")->value()->cast<FloatParameterValue>();
            if (parameter != nullptr)
                if (!parameter->value(45)) {
                    ui->messageBox("optimizeOrientationCriticalAngle failed!");
                    return true;
            parameter = orientation->parameters()->itemByName("optimizeOrientationDistanceToPlatform")->value()->cast<FloatParameterValue>();
                if (!parameter->value(0)) {
                    ui->messageBox("optimizeOrientationDistanceToPlatform failed !");
                    return true;
            booleanparameter = orientation->parameters()->itemByName("optimizeOrientationMoveToCenter")->value()->cast<BooleanParameterValue>();
            if (booleanparameter != nullptr)
                    ui->messageBox("optimizeOrientationMoveToCenter failed !");
                    return true;
            parameter = orientation->parameters()->itemByName("optimizeOrientationFrameWidth")->value()->cast<FloatParameterValue>();
                if (!parameter->value(0.5)) {
                    ui->messageBox("optimizeOrientationFrameWidth failed !");
                    return true;
            parameter = orientation->parameters()->itemByName("optimizeOrientationCeilingClearance")->value()->cast<FloatParameterValue>();
                    ui->messageBox("optimizeOrientationCeilingClearance failed!");
                    return true;
            Ptr<ChoiceParameterValue> choiceParameter = orientation->parameters()->itemByName("optimizeOrientationRankingSupportVolume")->value()->cast<ChoiceParameterValue>();
            if (choiceParameter != nullptr)
                if (!choiceParameter->value("10")) {
                    ui->messageBox("optimizeOrientationRankingSupportVolume failed !");
                    return true;
            choiceParameter = orientation->parameters()->itemByName("optimizeOrientationRankingSupportArea")->value()->cast<ChoiceParameterValue>();
                if (!choiceParameter->value("0")) {
                    ui->messageBox("optimizeOrientationRankingSupportArea failed!");
                    return true;
            choiceParameter = orientation->parameters()->itemByName("optimizeOrientationRankingBoundingBoxVolume")->value()->cast<ChoiceParameterValue>();
                if (!choiceParameter->value("2")) {
                    ui->messageBox("optimizeOrientationRankingBoundingBoxVolume failed !");
                    return true;
            choiceParameter = orientation->parameters()->itemByName("optimizeOrientationRankingPartHeight")->value()->cast<ChoiceParameterValue>();
                if (!choiceParameter->value("6")) {
                    ui->messageBox("optimizeOrientationRankingPartHeight failed !");
                    return true;
            choiceParameter = orientation->parameters()->itemByName("optimizeOrientationRankingCOGHeight")->value()->cast<ChoiceParameterValue>();
                    ui->messageBox("optimizeOrientationRankingCOGHeight failed !");
                    return true;
            Ptr<GenerateToolpathFuture> future = cam->generateToolpath(orientation);
            if(future != nullptr)
            Ptr<OptimizedOrientationResult> firstResult = nullptr;
            Ptr<GeneratedDataCollection> generatedResults = orientation->generatedDataCollection();
            Ptr<GeneratedData> primary = generatedResults->itemByIdentifier(GeneratedDataType::OptimizedOrientationGeneratedDataType);
            if (!primary) {
                ui->messageBox("failed !");
                return false;
            if (Ptr<OptimizedOrientationResults> castPref = primary->cast<OptimizedOrientationResults>()) {
                firstResult = castPref->item(0);
                if (!castPref->currentOrientationResult(firstResult)) {
                    ui->messageBox("Optimized Orientation Result failed !");
                    return true;
            // generating support
            Ptr<OperationInput> supportInput = setup->operations()->createInput("solid_volume_support");
            Ptr<Operation> volumeSupport = setup->operations()->add(supportInput);
            Ptr<CAMParameter> supportParameter = volumeSupport->parameters()->itemByName("supportTarget");
            //supportParameter.value.value = occs;
            Ptr<CadObjectParameterValue> _supportParameter = supportParameter->value()->cast<CadObjectParameterValue>();
            std::vector<Ptr<Base>> _occs;
            Ptr<Base> item = occs[0]->cast<Base>();
            if (!item) {
                ui->messageBox("occurrences is not typcast into Base class for support Target !");
                return false;
            if (!item->isValid()) {
                ui->messageBox("occurrence is not valid for supportTarget !");
                return false;
            _occs.push_back(item);
            if (!_supportParameter->value(_occs)) {
                ui->messageBox("Inserting value for support parameter is failed !");
                return true;
            future = cam->generateToolpath(volumeSupport);
            if (volumeSupport->hasError())
                volumeSupport->deleteMe();
        // Generating toolPath
        Ptr<Operation> toolpath = nullptr;
        for (size_t i = 0; i < setup->operations()->count(); ++i) {
            Ptr<Operation> op = setup->operations()->item(i);
            if (op->strategy() == "additive_buildstyle") {
                toolpath = op;
                break;
        if (toolpath == nullptr)
            return false;
        future = cam->generateToolpath(toolpath);
        while (future->isGenerationCompleted() == false) {
            std::this_thread::sleep_for(std::chrono::milliseconds(1000));
        app->activeViewport()->fit();
        // start the toolpath simulation command
        /*app->executeTextCommand("NaNeuCAMUI.AdditiveSimulateCmd");*/
    /// end
    //ui->messageBox("Hello addin");
    return true;
extern "C" XI_EXPORT bool stop(const char* context)
    if (ui)
        ui->messageBox("Stop addin");
        ui = nullptr;
    return true;
#ifdef XI_WIN
#include <windows.h>
BOOL APIENTRY DllMain(HMODULE hmodule, DWORD reason, LPVOID reserved)
    switch (reason)
    case DLL_PROCESS_ATTACH:
    case DLL_THREAD_ATTACH:
    case DLL_THREAD_DETACH:
    case DLL_PROCESS_DETACH:
        break;
    return TRUE;
#endif // XI_WIN
In these c++ code, instead of textPalette activation, ui->messageBox() is used.
After the executing these c++ code facing some issue as shown in the below image -
at line no. 333, value(_occs) method returns false. I don't know,  why?
CGBenner
@subhashraj8210
Hello and welcome!  I've moved your post here so that it can be seen by the experts who may best be able to help you.  Good luck!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
