Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what youโ€™ve discovered with the community.
Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Trouble removing item from TableCommandInput
0 REPLIES 0
Message 1 of 1
allan4EEKW
89 Views, 0 Replies
I have a table with some conditional commandInputs. In this example, clicking a checkbox should swap one textbox in the table for another. I'm doing this by removing the commandInput from the table via the removeInput method and then adding the new input to the table at that position. The following Python code should demonstrate the issue:
def command_created(args: adsk.core.CommandCreatedEventArgs๐Ÿ˜ž
    inputs = args.command.commandInputs
    global table
    global textBoxOn
    global textBoxOff
    table = inputs.addTableCommandInput('table', 'Table', 2, '1:1')
    toggleInput = inputs.addBoolValueInput('toggle', 'Toggle', True, '', True)
    textBoxOn = inputs.addTextBoxCommandInput('textBox_on', 'TextBox On', 'ON', 1, True)
    textBoxOff = inputs.addTextBoxCommandInput('textBox_off', 'TextBox Off', 'OFF', 1, True)
    table.addCommandInput(toggleInput, 0, 0, 0, 0)
    table.addCommandInput(textBoxOn, 0, 1, 0, 0)
    # Not adding textBoxOff because we don't want it in the table yet
    futil.add_handler(args.command.inputChanged, command_input_changed, local_handlers=local_handlers)
def command_input_changed(args: adsk.core.InputChangedEventArgs๐Ÿ˜ž
    global table
    global textBoxOn
    global textBoxOff
    if args.input.id == 'toggle':
        table.removeInput(0, 1) # Should not delete the TextBox, only remove it from the table
        if adsk.core.BoolValueCommandInput.cast(args.input).value:
        else:
            table.addCommandInput(textBoxOff, 0, 1, 0, 0)
gives the error:
RuntimeError: 4 : An API Object refers to a deleted Object
This would make sense if the documentation for the removeInput method didn't explicitly state that removed inputs aren't deleted from the parent's commandInputs. Am I missing something? Or am I encountering a bug?
0 REPLIES 0
