Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Trigger API from outside
2 REPLIES 2
infoSZ5ZG
711 Views, 2 Replies
is it possible to address the API from outside Fusion 360, like via the command line or an external python script?
Sorry for the newbie question!
D
2 REPLIES 2
marshaltu
in reply to: infoSZ5ZG
Unfortunately out-of-process API is supported yet. It means you cannot call the API directly outside Fusion 360 process.
Instead you can probably add an addin to Fusion 360 and let it talk to your app to receive/send data and then call into API by the addin. An example is like as below:
http://adndevblog.typepad.com/cloud_and_mobile/2016/03/practise-with-fusion-360-and-socketio-javascr...
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
Jellej
Probably a litte late for you, but to all future readers: This might be of help. http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-8A2C4ECD-7D82-4E56-AFE8-4FA72464AE66
You can open (or insert) a file via an url, and write a script that triggers when files are opent via an URL. Read the paragraph "Private info" for further details. It made me achieve this goal.
