Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Transformation of Occurence is not considered on STL export
2 REPLIES 2
benef453
236 Views, 2 Replies
I moved an object using the transform property:
trans = occ.transform
trans.translation = adsk.core.Vector3D.create(100, 0, 0)
occ.transform = trans
If I then export the occurence to STL this translation is not considered. In contrast, moving an object directly in the scene is considered for export.
How can I change the position of an object in the coordinate frame of the exported STL?
2 REPLIES 2
ekinsb
in reply to: benef453
The STL exporter is writing out the component. An occurrence is just a reference to the component so moving the occurrence doesn't have an impact on the referenced component.  One workaround if you need the STL in a specific position and orientation is to move the body within the component.
Brian Ekins
Mod the Machine blog
benef453
in reply to: ekinsb
That's what I was searching for, thank you!
