Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Toolbars - NEW UI
4 REPLIES 4
MichaelT_123
481 Views, 4 Replies
Toolbars - NEW UI
Hi TF360,
I tried recently to use some Addin(s) I have written in the ERA of OLD interface.
To no avail…
I have searched (only) a little bit through the code, but I could not find the problem.
The next move was to look at F360 documentation, particularly related to the recent change of UI (toolbars).
I have found the relaxing statement there:
Although the commands are organized differently, the commands themselves are not changed by the toolbar update
The following step was to run F360 supplied script allowing to spool the entire user interface command set.
 (http://help.autodesk.com/cloudhelp/ENU/Fusion-360-API/files/WriteUserInterfaceToFile_Sample.htm)
It has produced this result:
Failed:
Traceback (most recent call last):
  File "D:/Fusion360/API/Scripts/SpoolControls/SpoolControls.py", line 50, in run
    msg = '   ' + workspace.id + ' (' + str(workspace.toolbarPanels.count) + ')____\n'
  File "…/Autodesk/webdeploy/production/…dd09c95/Api/Python/packages\adsk\core.py", line 13624, in _get_count
    return _core.ToolbarPanels__get_count(self)
RuntimeError: 2 : InternalValidationError : tb
The above exception was the direct cause of the following exception:
SystemError: <built-in function delete_Workspaces> returned a result with an error set
Could you please check/clarify the problem?
Are there any changes/refinements necessary to OLD ADDIN SCRIPTS?
Regards
MichaelT
MichaelT
Tags (2)
4 REPLIES 4
kandennti
in reply to: MichaelT_123
Hi MichaelT_123.
        result += '\n\n** Workspaces  (' + str(ui.workspaces.count) + ')____\n'
        for workspace in ui.workspaces:
            if workspace.productType == '':
                continue
            try:
                result += msg
                for panel in workspace.toolbarPanels:
                    msg = '      ' + panel.id + '\n'
                    result += msg
            except:
                pass
MichaelT_123
in reply to: kandennti
Hi Kandennti-san,
<try: - except:> is a brutal trick... but it works ... most of the time :).
So, it seems that newly introduced  workspace(s) code is missing some classes, doesn't it?
I hope that it would be quite easy to patch the gap to make the statement :
once again truthful.
With Regards
MichaelT
MichaelT
kandennti
Excuse me. Last night I was sleepy and forgot the text.
The cause seems to be the NEST workspace.
It seems that the NEST workspace tool panel is only implemented. However,
it may not be available.(Not tried)
I tried using the len function instead of the count property.
                continue
            msg = '   ' + workspace.id + ' (' + str(len(workspace.toolbarPanels)) + ')____\n'
            result += msg
                result += msg
MichaelT_123
Great analysis Kandennti-san,
... even Sherlock Holmes could not has done better!
With Regards
MichaelT
MichaelT
