Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Tool tip / Command / Button definition title missing
4 REPLIES 4
scottmoyse
459 Views, 4 Replies
At some point... this has been broken in an update. All Add-Ins are showing this issue, not just mine.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
4 REPLIES 4
OceanHydroAU
in reply to: scottmoyse
Well spotted.  It works OK for buttons, but not anything inside dropdowns.
(The button is the "promoted" version of the first drop-down entry - literally the same definition, so they *should* be identical when viewed)
scottmoyse
in reply to: OceanHydroAU
Yes I had also noticed that and forgot to bring it up. Thanks for doing so.
Kind Regards
Scott Moyse
Manufacturing Technical Specialist Autodesk Expert Elite
P: +64 9 302 4028 M: +64 21 055 7775
scott.m@cadpro.co.nz
CADPRO Systems Ltd
Auckland - 527b Rosebank Road, Avondale Auckland
Christchurch - Unit 3, Kendal Avenue, Burnside
New Zealand
Scott Moyse
scottmoyse
This is happening with native commands in Fusion 360 as well.
Scott Moyse
scottmoyse
@goyals have you seen this?
It's worth noting that the native commands in the MFG workspace do display their titles in the sub-menu toolclips:
Scott Moyse
