Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Tool params not saving
1 REPLY 1
kealan4LBW
77 Views, 1 Reply
I'm trying to change parameter values with the API, tool_comment and tool_productId.
The function below reports blank / Null expressions when it first runs, and then shows the same parameters as having changed later on in the function.
However, if I go and look up the tool library, the parameters have not updated over there.
If I call the function twice, it reports the parameters being Null/Blank again the second time it runs - which is not as expected - so it's like the tool parameters aren't getting saved or something so they look OK from within the scope of the function but they're not getting pushed back out to fusion properly.
Any ideas?
for url in local_lib_url_list:
        local_lib_names.append(toolLibraries.displayName(url))
        toolLibrary = toolLibraries.toolLibraryAtURL(url)
        for tool in toolLibrary:
            futil.log(f"BEFORE Tool_comment value is: {tool.parameters.itemByName('tool_comment').expression}")
            futil.log(f"BEFORE Tool_productId value is: {tool.parameters.itemByName('tool_productId').expression}")
            item1 = tool.parameters.itemByName('tool_comment')
            item1.expression = "Scripted"
            item2 = tool.parameters.itemByName('tool_productId')
            item2.expression = "Scripted"
            futil.log(f"AFTER Tool_comment value is: {tool.parameters.itemByName('tool_comment').expression}")
            futil.log(f"AFTER Tool_productId value is: {tool.parameters.itemByName('tool_productId').expression}")
            #debug line  to check if manually edited library changes appear in the script read values.
            futil.log(f" Tool_vendor value is: {tool.parameters.itemByName('tool_vendor').expression}")
            futil.log("______________________END OF TOOL______________________________________________")
1 REPLY 1
kandennti
in reply to: kealan4LBW
Hi @kealan4LBW -San.
I have not tried it, but it looks like you probably need to do the ToolLibraries.updateToolLibrary method.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-A6D44A3E-7E21-4AEA-B561-BFB9F45F9F28
