Tool library .json file manipulation
CuttingEdgeManufacturing
Message 1 of 8
Hello all, I am working on software that keeps track of tooling inventory, culling most of the data from the readily available json file that f360 uses. i add in about 6-8 properties to the json file for my needs, and then put the file back where i got it.
however for some reason when i import my test library back to f360 it highlights the majority of tools in the library as if something is wrong with them. it still lets me go in and edit the tools but i can't find any issues with the tools. below is screenshot as well as sample of the json file. can anyone see what is wrong with this?
  "data": [
      "OrderQty": 0,
      "product-link": "6010",
      "Cost": 5.0,
      "Employee": "",
      "Location": "",
      "onHandQty": 0,
      "stockQty": 0,
      "orderQty": 0,
      "ReturnTool": false,
      "type": "thread mill",
      "vendor": "Gorilla Mill",
      "product-id": "GMDTTM58-11UN4FL",
      "description": "5/8-11\"",
      "BMC": "carbide",
      "GRADE": "Mill Generic",
      "geometry": {
        "CSP": false,
        "DC": 0.433,
        "HAND": true,
        "LB": 2.0,
        "LCF": 0.5,
        "NOF": 4,
        "NT": 1,
        "OAL": 5.0,
        "SFDM": 0.625,
        "TP": 0.0909091,
        "shoulder-length": 1.969,
        "thread-profile-angle": 60,
        "SIG": 0,
        "RE": 0.0,
        "TA": 0,
        "tip-diameter": 0.0,
        "tip-length": 0.0
      "guid": "0112c196-8a79-421d-8dda-d4aa964aa6d7",
      "holder": {
        "description": "Maritool CAT40-ER32-2.35",
        "guid": "e800051b-e2d6-4699-a2b6-dad6466a0a0c",
        "last_modified": "1485790626152",
        "product-id": "CAT40-ER32-2.35",
        "product-link": "",
        "segments": [
            "height": 0.148,
            "lower-diameter": 1.5,
            "upper-diameter": 1.97
            "height": 0.836,
            "lower-diameter": 1.97,
            "height": 0.176,
            "lower-diameter": 1.57,
            "upper-diameter": 1.57
            "height": 0.09,
            "upper-diameter": 1.75
            "height": 0.425,
            "lower-diameter": 1.75,
            "height": 0.05,
            "upper-diameter": 1.85
            "height": 0.03,
            "lower-diameter": 2.442,
            "upper-diameter": 2.502
            "height": 0.145,
            "lower-diameter": 2.502,
            "height": 0.079,
            "upper-diameter": 2.215
            "height": 0.118,
            "lower-diameter": 2.215,
            "height": 0.079,
            "height": 0.143,
            "height": 0.03,
            "upper-diameter": 2.442
            "height": 0.125,
        "type": "holder",
        "unit": "inches",
        "vendor": "Maritool"
      "post-process": {
        "break-control": false,
        "comment": "",
        "diameter-offset": 17,
        "length-offset": 17,
        "live": true,
        "manual-tool-change": false,
        "number": 17,
        "turret": 0
      "start-values": {
        "presets": [
            "description": "",
            "f_n": 0.012242786571039,
            "f_z": 0.0031,
            "guid": "eac33213-4083-35b8-afe3-17bd42a249f0",
            "n": 4410.xxx-xxxxxxxx,
            "n_ramp": 44110.0,
            "name": "1018",
            "tool-coolant": "flood",
            "use-stepdown": false,
            "use-stepover": false,
            "v_c": 499.99999999999937,
            "v_f": 54.6934307900093,
            "v_f_leadIn": 54.0,
            "v_f_leadOut": 54.0,
            "v_f_plunge": 54.0,
            "v_f_ramp": 54.0,
            "v_f_retract": 0.0,
            "stepdown": 0.0,
            "stepover": 0.0
            "description": "",
            "f_n": 0.010769117817118,
            "f_z": 0.0028,
            "guid": "f35f5601-68a9-477b-b4b0-2ffeedb3bef1",
            "n": 1764.3042190325598,
            "n_ramp": 1764.0,
            "name": "4140",
            "v_c": 200.0,
            "v_f": 19.7602072531647,
            "v_f_leadIn": 19.0,
            "v_f_leadOut": 19.0,
            "v_f_plunge": 19.0,
            "v_f_ramp": 19.0,
            "v_f_retract": 0.0,
            "stepdown": 0.0,
            "stepover": 0.0
            "description": "",
            "f_n": 0.012091641057817,
            "f_z": 0.0031,
            "guid": "b118ce46-da35-4ed6-9806-b98e05ffe077",
            "n": 2646.xxx-xxxxxxxx,
            "n_ramp": 2646.0,
            "name": "Tool Steel",
            "v_c": 300.0,
            "v_f": 32.8160584740056,
            "v_f_leadIn": 32.0,
            "v_f_leadOut": 32.0,
            "v_f_plunge": 32.0,
            "v_f_ramp": 32.0,
            "v_f_retract": 0.0,
            "stepdown": 0.0,
            "stepover": 0.0
            "description": "",
            "f_n": 0.01118476797848,
            "f_z": 0.0028,
            "guid": "0e1767f5-b0ef-422f-b49d-6cb8c3eb06ed",
            "n": 3308.0704106860494,
            "n_ramp": 3308.0,
            "name": "Stainless Steel",
            "v_c": 375.0,
            "v_f": 37.0503885996837,
            "v_f_leadIn": 37.0,
            "v_f_leadOut": 37.0,
            "v_f_plunge": 37.0,
            "v_f_ramp": 37.0,
            "v_f_retract": 0.0,
            "stepdown": 0.0,
            "stepover": 0.0
      "unit": "inches"
"version": 0
Replies (7)
Message 2 of 8
boopathi.sivakumar
From the given sample it didn't give me any warnings, Could you send me over the .json file i can take a look into it
Boopathi Sivakumar
Senior Technology Consultant
Message 3 of 8
couldn't find a way to attach file in PM so here is the json file.
Message 4 of 8
I can able to see couple of issues with the .json
the grade should not be null it must be one of
  • "Mill Generic"
  • "generic"
And if you don't have any holders it should not also be null, It has to be removed from the data object.
I have added the modified file for your reference
Boopathi Sivakumar
Message 5 of 8
ah, thought i fixed that issue. thanks for that. I didn't look through it too hard thinking i had those issues fixed!
Message 6 of 8
looks like my preset speeds and feeds for endmills it doesn't like that i set stepdown and stepover to false, but also set the values for them to 0.0" so if stepdown is false ignore the value for this as well?
Message 7 of 8
It seems like a bug to me.. If "use-stepdown" and "use-stepover" is false then it shouldn't look for the stepdown and stepover value.. will report to the team.
Boopathi Sivakumar
Message 8 of 8
fixed it on my end. but yea seems like a bug. thanks for the help!
