Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Timing Belt Pulley Script and Bug Report.... Probably Not a Bug
3 REPLIES 3
marc.a.grossman
839 Views, 3 Replies
I'm having some trouble with my first Fusion 360 python script. Basically, I'd like to create a script to automatically generate timing belt pulleys. I'm going to make them according to the shapes defined in this catalog.
Here is the screencast. The insert screencast url is not working: http://autode.sk/2oKWiwu
I've got a basic script that just executes. Eventually, I'll add a dialog and options for many different tooth profiles, but I'm stuck at square one for now. Please have a look at the screencast.
The couple relevant lines of code are:
# a few parameters
toothPitch = 0.080
toothWidth = 0.030
troughDepth = 0.018
#insert the line that will be the bottom of the tooth in the pulley
toothSketch.sketchCurves.sketchLines.addByTwoPoints(adsk.core.Point3D.create(-0.5*toothWidth, pulleyOD/2.0-troughDepth,0), adsk.core.Point3D.create(0.5*toothWidth, pulleyOD/2.0-troughDepth, 0))
What's strange is that the points should clearly be at an x position of -0.015" and +0.015", but they're coming in at -0.006" and +0.006" and I'm not sure why.
What's strange too is that when I do a print of the x coord of one of the points it's calculated correctly as this:
print(-0.5*toothWidth)
prints out to the "terminal" -0.015"
as you'll see in my demo.
Thanks in advance to anyone that has a look and helps me solve this.
3 REPLIES 3
Ok. I was able to insert the screencast now. Not sure why it wasn't appearing earlier. Maybe it just takes time to become "active".
Any help would be greatly appreciated.
-Marc
Screencast will be displayed here after you click Post.
9efd3fb9-c318-4d44-ae65-02f77efbd876
Now can someone  tell me why it's appearing like this:
It says "Screencast will be displayed here after you click Post."
but I see no screencast. There are a few bugs to talk about I guess
-Marc
Ok everyone here's the deal. I kinda thought it was something like this because my stuff was off by 2.5 (very close to 2.54). All units are in cm. You have to convert. Here's a great article on the subject. Glad I managed to stumble across it.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-A81B295F-984A-4039-B1CF-B449BEE893D7
-Marc
