Announcements
This looks like legal Python - why won't it run within the API?
william-c-anderson
william-c-anderson
Here's some Python code (which works as expected in, say, the Idle interpreter):
prog='def _square(x):\n\treturn x*x\n'
exec(prog)
sq = _square(42)
print(sq)
In Idle, this returns 1764 as expected. In the F360 API environment, it gets this result:
NameError: name '_square' is not defined
This is particularly frustrating when, in the VS Code debugger, I can see the name _square defined as a function in the left column.
What can I do to get exec() to work correctly in the API?
william-c-anderson
I've answered my own question: a scope identifier is needed, depending upon how deep you are in the module. One of the following should work:
prog='global _square\ndef _square(x):\n\treturn x*x\n'
or
prog='nonlocal _square\ndef _square(x):\n\treturn x*x\n'
BTW, I don't actually use this in my API code...
kandennti
Hi @william-c-anderson .
I am a little interested.
What kind of scene is creating a function dynamically?
I can think of a scene where a method is dynamically added to the Fusion360 API object.
william-c-anderson
@kandennti -san, I'll answer your question when the add-in is finished - I've finally gotten it mostly working. Sorry to be so "mysterious" šŸ˜‰ I still need to resolve a few issues with the constraint engine to make it work the way I want it to.
Thanks for so much help!
