thicken feature problems
normally I use 'rootComp.createOpenProfile' for the creation of extrusion and then I canuse the thicken feature. For the following body I use sweep, it is not working with the openProfile command and the thicken feature is not working at all.Hopefully someone could help me to exlpain my mistake.
Thank you in advance,
Janina
The code:
        # Creation of construction Point and Vector for Plane
        Point= adsk.core.Point3D.create(0,-h1,0)
        normal = adsk.core.Vector3D.create(0,0,1)
        plane = adsk.core.Plane.create(Point,normal)
        cons_planes = rootComp.constructionPlanes
        # Determine as construction plane
        cons_planeInput = cons_planes.createInput()
        cons_planeInput.setByPlane(plane)
        cons_plane = cons_planes.add(cons_planeInput)
        # Create a new sketch
        sketch0 = rootComp.sketches.add(cons_plane)
        # Draw a separation line
        lines = sketch0.sketchCurves.sketchLines;
        line1_endpoint = adsk.core.Point3D.create((D/2), 0, 0)
        line1_startpoint = adsk.core.Point3D.create(-(D/2), 0, 0)
        line1= lines.addByTwoPoints(line1_startpoint, line1_endpoint)
        # Draw a dish
        arcs = sketch0.sketchCurves.sketchEllipses
        majorAxisPoint = adsk.core.Point3D.create(0, -hz, 0)
        Point = adsk.core.Point3D.create((D/2), 0, 0)
        centerSketchPoint = adsk.core.Point3D.create(0, 0, 0)
        ellipsearc = arcs.add(centerSketchPoint,majorAxisPoint,Point)
        ellipsearc.split(line1_endpoint)
        # Get the profile
        prof = sketch0.profiles.item(0)
        Point1= adsk.core.Point3D.create(0,-h1,0)
        normal1 = adsk.core.Vector3D.create(0,1,0)
        plane1 = adsk.core.Plane.create(Point1,normal1)
        cons_planes1 = rootComp.constructionPlanes
        cons_planeInput1 = cons_planes1.createInput()
        cons_planeInput1.setByPlane(plane1)
        cons_plane1 = cons_planes1.add(cons_planeInput1)
        # Create profile 1
        sketch1 = rootComp.sketches.add(cons_plane1)
        sketchCircles1 = sketch1.sketchCurves.sketchCircles
        centerPoint1 = adsk.core.Point3D.create (0,0,0)
        circle1 = sketchCircles1.addByCenterRadius(centerPoint1, (D/2))
        #path = rootComp.createOpenProfile(circle1)
        # Create path
        path = rootComp.features.createPath(circle1)
        # Create a sweep input
        sweeps = rootComp.features.sweepFeatures
        sweepInput = sweeps.createInput(prof, path, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        #sweepInput.isSolid = False
        # Create the sweep.
        sweep = sweeps.add(sweepInput)
        # Get the body
        body = sweep.bodies.item(0)
        # Create thicken feature
        thickenFeatures = rootComp.features.thickenFeatures
        inputFaces = adsk.core.ObjectCollection.create()
        bodies = sweep.bodies
        for body in bodies :
            inputFaces.add(body)
        thickenInput = thickenFeatures.createInput(inputFaces, sd, False, adsk.fusion.FeatureOperations.NewBodyFeatureOperation)
        thickenFeatures.add(thickenInput)
marshaltu
Unfortunately the sample you posted cannot be run in my machine as some codes were missing. It would be good if you can provide a workable sample.
I guess you were trying to thicken a solid body, which we don't support in Fusion 360. Please refer to API help for details.
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-2af69699-cc1a-4095-8b88-2f8ab2dcd595
Marshal
Marshal Tu
Fusion Developer
