Tabs do not respect isEnabled or isVisable
Documentation indicates isEnabled and isVisable should be supported, but in practice setting these does nothing.
The Command Inputs API Sample can be used as base code to verify this.
marshaltu
If you meant "TabCommandInput", I can reproduce the issue. The two methods didn't work for tab command input. I will log a bug in our internal system to track it.
Marshal
Marshal Tu
Fusion Developer
