Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Switching on UMR in Spyder invoked from Fusion?
2 REPLIES 2
300 Views, 2 Replies
I'm debugging a python script in spyder invoked from Fusion.
My python code calls functions in another python file. The spyder system
keeps the original python file in a cache, so when I edit the file the changes
aren't seen by the interpreter. The online Spyder documentation says
there is a switch to use "UMR" (User module reload) so the file is reloaded
from disk, but it doesn't give detailed instructions on finding the switch
on the UI.
Where is the UMR switch? Is Autodesk's version of Spyder (2.3.2) different?
2 REPLIES 2
marshaltu
The option for UMR may be removed unexpectedly when we customized Spyder. The version we included in Fusion 360 was a little different from official one. We have to make some customization so that Spyder can work well with Fusion 360.
We will bring it back when we upgrade Spyder version in the future.
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
in reply to: marshaltu
Thank you for the reply.
I hope this get fixed quickly, because it is a major pain.
