Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Surface types of non-uniformly scaled Cylinder and Cone
1 REPLY 1
burzins
316 Views, 1 Reply
When non-uniformly scaled, Surface.objectType and Surface.surfaceType for a Sphere and Torus are both
adsk::core::NurbsSurface and 7
However, for non-uniformly scaled Cylinders and Cones, the properties are, respectively:
adsk::core::Cylinder and 1
adsk::core::Cone and 2
Should the latter two instead be the following?:
adsk::core::EllipticalCylinder and 5
adsk::core::EllipticalCone and 6
Thank you,
Steve
1 REPLY 1
ekinsb
in reply to: burzins
Thank you for reporting this.  I've verified the problem and have reported a bug.
Brian Ekins
Mod the Machine blog
