Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Surface Normal of BrepFace
2 REPLIES 2
ebunn3
369 Views, 2 Replies
Is there a way to determine the surface normal of a selected face using the API?
For example (see screenshot below):
  • I want to determine which direction the surface is facing.
  • I believe the surface normal would tell me this?  But I am not sure.
Any help would be greatly appreciated.
Eric
2 REPLIES 2
kandennti
in reply to: ebunn3
Hi @ebunn3 .
The normal direction of a surface can be obtained by using the SurfaceEvaluator object.
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-31dad9b2-ee1d-4216-8100-09ea44f9967a
This sample creates a sketch line in the normal direction when you click on the surface of the body.
# Fusion360API Python script
import traceback
import adsk.fusion
import adsk.core
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.fusion.Application = adsk.core.Application.get()
        ui = app.userInterface
        des: adsk.fusion.Design = app.activeProduct
        root: adsk.fusion.Component = des.rootComponent
        msg: str = 'Click Face /ESC - Cancel'
        selFiltter: str = 'Faces'
        skt: adsk.fusion.Sketch = None
        while True:
            # select face
            sel: adsk.core.Selection = selectEnt(msg, selFiltter)
            if not sel:
                break
            face: adsk.fusion.BRepFace = sel.entity
            click: adsk.core.Point3D = sel.point
            # get SurfaceEvaluator
            eva: adsk.core.SurfaceEvaluator = face.evaluator
            # get Normal
            normal: adsk.core.Vector3D
            _, normal = eva.getNormalAtPoint(click)
            normal.normalize()
            # target point
            target: adsk.core.Point3D = click.copy()
            target.translateBy(normal)
            # sketch
            if not skt:
                skt = root.sketches.add(root.xYConstructionPlane)
                skt.name = 'Normal'
            # create Normal Line
            skt.sketchCurves.sketchLines.addByTwoPoints(click, target)
        if skt:
            skt.deleteMe()
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
def selectEnt(
        msg: str,
        filtterStr: str) -> adsk.core.Selection:
    try:
        app = adsk.core.Application.get()
        sel = ui.selectEntity(msg, filtterStr)
        return sel
    except:
        return None
1.pngHere we have used the getNormalAtPoint method.
Note that "BRepFace.evaluator" and "BRepFace.geometr.evaluator" are not strictly the same.
ebunn3
in reply to: kandennti
@kandennti
Thank you so much.  This does exactly what I need.
Eric
