Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Strange behaviour of Appearances.addByCopy method
1 REPLY 1
VismantasKizelis
278 Views, 1 Reply
Hello
Working on add-in for Fusion360 I found a strange behaviour of Appearances.addByCopy method.
I work on Windows 10 machine. The same bug reproduces on both c++ and py scripts
Steps to reproduce:
  1. Open some document
  2. Write the script to copy any appearance from library to current design using Appearances.addByCopy method
  3. Copy the same appearance several times providing different display name each time
Results:
  1. Sometimes everything wokrs as expected
  2. Sometimes adding new copy of appearance to design overwrites another appearance that was added previously
  3. Sometimes new name is ignored and appearance is added to design with original name
In screencast you can see, that same script, that should add six appearances to design, in first document adds three appearances, in second and third documents adds two appearances (but one appearance has wrong name), in other documents script acts as expected.
83f6ecea-41bb-4023-b545-bbcecae0f4b4
Do not know why screencast does not show, so here is the link https://autode.sk/2so4YeR
py script:
import adsk.core, adsk.fusion, adsk.cam, traceback
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
materialLibs = app.materialLibraries
matLib = materialLibs.item(1)
appear = matLib.appearances.item(0)
des = adsk.fusion.Design.cast(app.activeProduct)
#Next lines should add six appearances to current design
des.appearances.addByCopy(appear, "A")
des.appearances.addByCopy(appear, "A1")
des.appearances.addByCopy(appear, "A2")
des.appearances.addByCopy(appear, "A3")
des.appearances.addByCopy(appear, "A4")
des.appearances.addByCopy(appear, "A5")
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
1 REPLY 1
Thank you for reporting the issue to us. UP-39107 has been logged to track the issue in our internal system.
Marshal
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
