I copied the sketchpoints add C++ example and posted it into my C++ add-in.
// Get sketch texts
Ptr<SketchPoints> sketchPoints = toothSketch->sketchPoints(); // NOTE: toothSketch has been changed from the sample but is a valid sketch
if (!sketchPoints)
return false;
// Create sketch point
Ptr<Point3D> point = Point3D::create(1.0, 1.0, 0);
Ptr<SketchPoint> sketchPoint = sketchPoints->add(point); // compile error
if (!sketchPoint)
return false;
The sketchPoints->add(point) line gives me the following error:
adsk::fusion::sketchpoints C++ pointer or reference to incomplete type
Btw, using Visual Studio 2022 on Windows 11.
Please help.
Solved by ArjayHawco. Go to Solution.
It looks like the error is probably coming from the 'toothSketch' variable - can you post the code where that is initialized/any additional context where that sketch is coming from?
John, thanks for taking the time to respond. I think I may have figured it out.
When I started my add-in, I basically copied the code from the spurgear.cpp sample.
This sample has a bunch of #include statements which a new c++ sample add-in doesn't include.
When I remove these extra #include statements the sketchPoints->Add problem goes away.
Extra spurgear sample includes:
#include <Core/Utils.h>
#include <Core/Application/Application.h>
#include <Core/Application/Product.h>
#include <Core/Application/ValueInput.h>
#include <Core/Application/UnitsManager.h>
#include <Core/Application/ObjectCollection.h>
#include <Core/Geometry/Point3D.h>
#include <Core/Geometry/Matrix3D.h>
#include <Core/Geometry/Surface.h>
#include <Core/Geometry/Curve3D.h>
#include <Core/Geometry/Line3D.h>
#include <Core/UserInterface/UserInterface.h>
#include <Core/UserInterface/CommandCreatedEventHandler.h>
#include <Core/UserInterface/CommandCreatedEvent.h>
#include <Core/UserInterface/CommandCreatedEventArgs.h>
#include <Core/UserInterface/CommandEvent.h>
#include <Core/UserInterface/CommandEventArgs.h>
#include <Core/UserInterface/CommandEventHandler.h>
#include <Core/UserInterface/ValidateInputsEventHandler.h>
#include <Core/UserInterface/ValidateInputsEvent.h>
#include <Core/UserInterface/ValidateInputsEventArgs.h>
#include <Core/UserInterface/InputChangedEventHandler.h>
#include <Core/UserInterface/InputChangedEvent.h>
#include <Core/UserInterface/InputChangedEventArgs.h>
#include <Core/UserInterface/Command.h>
#include <Core/UserInterface/CommandDefinition.h>
#include <Core/UserInterface/CommandDefinitions.h>
#include <Core/UserInterface/CommandInputs.h>
#include <Core/UserInterface/ValueCommandInput.h>
#include <Core/UserInterface/StringValueCommandInput.h>
#include <Core/UserInterface/DropDownCommandInput.h>
#include <Core/UserInterface/ListItems.h>
#include <Core/UserInterface/ListItem.h>
#include <Core/UserInterface/ImageCommandInput.h>
#include <Core/UserInterface/TextBoxCommandInput.h>
#include <Core/UserInterface/ToolbarPanelList.h>
#include <Core/UserInterface/ToolbarPanels.h>
#include <Core/UserInterface/ToolbarPanel.h>
#include <Core/UserInterface/ToolbarControls.h>
#include <Core/UserInterface/ToolbarControl.h>
#include <Core/UserInterface/CommandControl.h>
#include <Core/UserInterface/Workspaces.h>
#include <Core/UserInterface/Workspace.h>
#include <Core/Application/Attributes.h>
#include <Core/Application/Attribute.h>
#include <Fusion/Fusion/Design.h>
#include <Fusion/Components/Component.h>
#include <Fusion/Components/Occurrences.h>
#include <Fusion/Components/Occurrence.h>
#include <Fusion/BRep/BRepFaces.h>
#include <Fusion/BRep/BRepFace.h>
#include <Fusion/BRep/BRepEdges.h>
#include <Fusion/BRep/BRepEdge.h>
#include <Fusion/BRep/BRepBody.h>
#include <Fusion/Construction/ConstructionPlane.h>
#include <Fusion/Sketch/Sketches.h>
#include <Fusion/Sketch/Sketch.h>
#include <Fusion/Sketch/SketchCurves.h>
#include <Fusion/Sketch/SketchLines.h>
#include <Fusion/Sketch/SketchLine.h>
#include <Fusion/Sketch/SketchArcs.h>
#include <Fusion/Sketch/SketchArc.h>
#include <Fusion/Sketch/SketchPoint.h>
#include <Fusion/Sketch/SketchFittedSplines.h>
#include <Fusion/Sketch/SketchFittedSpline.h>
#include <Fusion/Sketch/SketchCircles.h>
#include <Fusion/Sketch/SketchCircle.h>
#include <Fusion/Sketch/GeometricConstraints.h>
#include <Fusion/Sketch/TangentConstraint.h>
#include <Fusion/Sketch/Profile.h>
#include <Fusion/Sketch/Profiles.h>
#include <Fusion/Sketch/ProfileLoops.h>
#include <Fusion/Features/Features.h>
#include <Fusion/Features/ExtrudeFeatures.h>
#include <Fusion/Features/ExtrudeFeatureInput.h>
#include <Fusion/Features/ExtrudeFeature.h>
#include <Fusion/Features/FilletFeatures.h>
#include <Fusion/Features/FilletFeatureInput.h>
#include <Fusion/Features/FilletFeature.h>
#include <Fusion/Features/CircularPatternFeatures.h>
#include <Fusion/Features/CircularPatternFeatureInput.h>
#include <Fusion/Features/CircularPatternFeature.h>
#include <Fusion/Fusion/Timeline.h>
#include <Fusion/Fusion/TimelineObject.h>
#include <Fusion/Fusion/TimelineGroups.h>
#include <Fusion/Fusion/TimelineGroup.h>
#include <sstream>
#define _USE_MATH_DEFINES
#include <math.h>
#include <memory>
#if defined(_WINDOWS) || defined(_WIN32) || defined(_WIN64)
#include <windows.h>
#else
#include <dlfcn.h>
#endif
using namespace adsk::core;
using namespace adsk::fusion;
New sample includes:
#include <Core/CoreAll.h>
#include <Fusion/FusionAll.h>
#include <Cam/CamAll.h>
using namespace adsk::cam;
Ptr<Application> app;
Ptr<UserInterface> ui;
Thanks for your help. I really appreciate it.
Arjay
The XXXAll.h files include every header file. Although it looks like the Spur Gear sample includes a lot more, it only includes the needed files rather than everything. I would guess that you have some additional code that's not in the Spur Gear add-in that requires adding the includes for that functionality.
