Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Sketches to one DXF
3 REPLIES 3
marylou.forsyth
151 Views, 3 Replies
Sketches to one DXF
I have been learning and searching for days now and I will admit I have to be missing something and it could be basic.  There are wonderful examples how to make a DXF file from an existing active model, but from the python code I am just not able to get the body and the wanted sketches.  I can each sketch exported as its own dxf fine.  I can see each sketch and its name, but when I go and project the sketches I want, I am only getting the body.  Here is the code:
                            design : adsk.fusion.Design = app.activeProduct
                            rootComp = design.rootComponent
                            sketches = rootComp.sketches
                            folder = "W:\\SharedData\\Fusion_360\\DXF\\"
                            fullPath = os.path.join(folder, order)
                            i1 = 0
                            for sk in sketches:
                                sketch = sketches.item(i1)
                                # Get sketch health state
                                health = sketch.healthState
                                if health == adsk.fusion.FeatureHealthStates.ErrorFeatureHealthState or health == adsk.fusion.FeatureHealthStates.WarningFeatureHealthState:
                                    ui.messageBox(sketch.errorOrWarningMessage)
                                if ("Pen_Line" in sketch.name or "Block" in sketch.name😞
                                    sketch.saveAsDXF(fullPath + sketch.name + '.dxf')
                                i1 = i1 + 1
                            #=================WORKS GREAT TO HERE========================
                            #Creates a new sketch on the specified planar entity
                            master: adsk.fusion.Sketch = rootComp.sketches.add(rootComp.xYConstructionPlane)
                            targetBody: adsk.fusion.BRepBody = rootComp.bRepBodies[0]
                            #Projects the specified entity or entities onto
                            # the x-y plane of the sketch and returns the created sketch entity(s)
                            project_result = master.project(targetBody)
                            if project_result == False:
                                print('Failure in DXF processing')
                            sketch_names = []
                            sk_cnt = 0
                            for rtskcnt in rootComp.sketches:
                                ohmyname = rootComp.sketches.item(sk_cnt).name
                                sketch_names.append(rootComp.sketches.item(sk_cnt).name)
                                master.include(rootComp.sketches.item(sk_cnt))
                                sk_cnt = sk_cnt + 1
                            project_result = master.project(rootComp.sketches)
                            app.log(str(sketch_names))
                            # write the merged file
                            master.saveAsDXF(fullPath + '.dxf')
                            msg = '!!  DXF file has been written !!'
                            print(msg)
                            futil.log(msg)
I have also attempted projecting the ...item but I can't get anything to work.  I DO get all the individual dxf files with the sketches and one for the body, I am so close hoping someone can see what I can't.  Thank you in advance!!!
PS. Master is the new sketch made to contain all the sketches and body.
3 REPLIES 3
I believe its my understanding of the documentation of entity.  I am thinking there is one entity associated with one sketch but I can't make the connection.  Any help is pointers (ie look here) are welcomed to!
kandennti
in reply to: marylou.forsyth
Hi @marylou.forsyth .
There were a number of unclear parts.
It was a bit confusing to me, but how about a process like this?
# Fusion360API Python script
import traceback
import adsk.core
import adsk.fusion
import pathlib
def run(context):
    ui = adsk.core.UserInterface.cast(None)
    try:
        app: adsk.core.Application = adsk.core.Application.get()
        ui = app.userInterface
        rootComp: adsk.fusion.Component = design.rootComponent
        exportFolder = pathlib.Path(r'C:\temp')
        healthStatesErrorOrWarning = [
            adsk.fusion.FeatureHealthStates.ErrorFeatureHealthState,
            adsk.fusion.FeatureHealthStates.WarningFeatureHealthState,
        targetSketchNames = [
            'Pen_Line',
            'Block'
        sketches: adsk.fusion.Sketches = rootComp.sketches
        sketch: adsk.fusion.Sketch = None
        for sketch in sketches:
            if health in healthStatesErrorOrWarning:
            if sketch.name in targetSketchNames:
                path = exportFolder / f'{sketch.name}.dxf'
                sketch.saveAsDXF(str(path))
        # Get all sketch elements of the root component
        sketchEntities: adsk.core.ObjectCollection = adsk.core.ObjectCollection.create()
        for sketch in rootComp.sketches:
            [sketchEntities.add(ent) for ent in sketch.sketchCurves]
            [sketchEntities.add(ent) for ent in sketch.sketchPoints]
        # Create Sketch
        master.name = 'Master'
        # Project Body
        project_result: adsk.core.ObjectCollection = master.project(targetBody)
        if project_result.count < 1:
            print('Failure of the body project')
        # Include sketchEntities
        master.include(sketchEntities)
        # Project sketchEntities
        master.project(sketchEntities)
        # Export DXF
        path = exportFolder / f'{master.name}.dxf'
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Wow you are fantastic!  I am sorry parts were unclear for you, thank you for plowing through it to understand my issue(s) you have totally saved me hours of work!  The entity handling is SO different than my concept thank you for the education and sharing.  You get a gold star from me and thats not easy!!
