Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Sketch.projectToSurface Method error
5 REPLIES 5
BradAndersonJr
412 Views, 5 Replies
Hey!
When I try to run my script using projectToSurface I get the error:
NotImplementedError: Wrong number or type of arguments for overloaded function 'Sketch_projectToSurface'.
The line of code is:
fretProject = sketch8.projectToSurface(topFace, fretLines, adsk.fusion.SurfaceProjectTypes.AlongVectorSurfaceProjectType, dirLine)
According to the Object inspector in Spyder 2 it states:
Sketch.projectToSurface(faces, curves, projectType, directionEntity):
Hopefully I'm just missing something simple... again.
Thanks!
Brad Anderson Jr
Fusion 360 Hobbyist
Fusion 360 Luthiers Facebook Group
5 REPLIES 5
marshaltu
in reply to: BradAndersonJr
I did a testing and it worked well in my side. I created a box and several sketch curves and then project the curves to faces of the box.
Marshal
import adsk.core, adsk.fusion, traceback
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        design = adsk.fusion.Design.cast(app.activeProduct)
        root = design.rootComponent
        body = root.bRepBodies.item(0)
        faces = []
        for face in body.faces:
            faces.append(face)
        sketch = root.sketches.item(0)
        curves = []
        for curve in sketch.sketchCurves:
            curves.append(curve)
        newsketch = root.sketches.add(root.xZConstructionPlane)
        newsketch.projectToSurface(faces, curves, adsk.fusion.SurfaceProjectTypes.AlongVectorSurfaceProjectType, root.yConstructionAxis)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Marshal Tu
Fusion 360 Developer
Autodesk, Inc.
BradAndersonJr
in reply to: marshaltu
Hey Marshal!
Thanks for the reply!  I played with the code you supplied it and worked great.  Is there a way to project to only 1 face, and not the whole body?
Thanks!
Brad Anderson Jr
Fusion 360 Hobbyist
marshaltu
You can probably declare a list of faces and append only on face and then call sketch.projectToSurface API.
Marshal
faces = []
faces.append(yourface)
Marshal Tu
Autodesk, Inc.
BradAndersonJr
Thanks again Marshal!
From my attempts I've found that .projectToSurface requires:
faces : An array of BRepFace objects that the curves will be projected onto.
Whenever I tried using a single face from my list, the script would fail.  As soon as I used multiple faces it would properly execute the script.  I don't know if this is intended to not allow a single face to be called.  I found a work around by specifying the single face I wanted to project curves onto using a slice within the list and setting an iteration to skip the rest of the faces.  My results look like:
body = rootComp.bRepBodies.item(0)
bodyFaces = []
    bodyFaces.append(face)
bodySurf = bodyFaces[6::2]
Thanks again!
Brad Anderson Jr
Fusion 360 Hobbyist
marshaltu
I guess the root cause was because the face you picked is parallel to project direction so that no curves can be projected. I give a quick test. I will see an error message if I pick a invalid face. It successes if I pick a valid face.
Marshal
def run(context):
    ui = None
    try:
        face = ui.activeSelections.item(0).entity
        faces = []
        faces.append(face)
        curves = []
    except:
        if ui:
Marshal Tu
Autodesk, Inc.
