I would like help with the following problem.
I want to include a spline inside a sketch that already contains a line, and make two constraints: the first with the first point of the line and the spline, and the second, between the end point of the line and the middle of the spline.
But I encounter the problem of a line dimension error after the constraints (decreasing its size).
Here's the code and photo of the error found.
Note 1: I really need to insert the spline in the sketch, as this is just a test for another application, where it is necessary to perform this operation.
Note 2: I need the line to remain the same 8 cm as it initially has.
Thank you very much,
Vitor Urel
